The Raven Posted July 27, 2018 Share Posted July 27, 2018 As above. I was under the impression that its due to the car not finding Trac? Am i wrong? Id like to have it back and if i can fool the car into using it id be most happy Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted July 27, 2018 Share Posted July 27, 2018 Have you spoken to DavidP the autobox wizzard about this? Quote Link to comment Share on other sites More sharing options...
David P Posted July 27, 2018 Share Posted July 27, 2018 My first suspicion would be the ECU? http://www.mkivsupra.net/vbb/showthread.php?348640-TT-Auto-not-shifting-in-4-no-manu-light Try swapping in an ECU from an auto Supra with working MANU mode. Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 28, 2018 Author Share Posted July 28, 2018 I was told that no N/A to TT swaps would work and its the norm rather than there being a fault Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 28, 2018 Author Share Posted July 28, 2018 OK i done some digging and found my old thread and the one from Keron http://www.mkivsupra.net/vbb/showthread.php?315329-Na-to-tt-overdrive-light-flashing&highlight=manu+mode Heres a quote from Keron "you will get this if the car has had a na-tt transplant as it recognises that there is no traction control etc. the od light will flash but will still work as normal. the manu light also does not show when pressing it too. the only way to get around this is by fitting tc and abs (if you dont have it already) as well as changing ALL of the wiring looms in the car...i mean all of them. whole car...." Quote Link to comment Share on other sites More sharing options...
David P Posted July 28, 2018 Share Posted July 28, 2018 If that's what Keron say's, then that's the way it is. Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 28, 2018 Author Share Posted July 28, 2018 If that's what Keron say's, then that's the way it is. I have abs there must be a way to fool it to think it has trac Quote Link to comment Share on other sites More sharing options...
David P Posted July 28, 2018 Share Posted July 28, 2018 The only way in my repertoire of electrickery, would be to fit it and then turn it off because it's useless? Quote Link to comment Share on other sites More sharing options...
