WIDESUPRA Posted July 20, 2018 Share Posted July 20, 2018 Ive put new master cylinder in my non-turbo, ive bled the clutch and all air has leaked out, the problem im facing now is that its only built pressure enough to push the clutch half way up after that it needs my help to pull it back up fully. Pleasd help as ive now come to a point where im giving up . Thanks Quote Link to comment Share on other sites More sharing options...
evinX Posted July 20, 2018 Share Posted July 20, 2018 I may be wrong, but i seem to remember seeing a manual gearbox with vacuum lines or similar? perhaps ones loose or damaged? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted July 20, 2018 Share Posted July 20, 2018 Was the replacement master cylinder a genuine and correct one? other than that i suspect there is still air in the system. Quote Link to comment Share on other sites More sharing options...
WIDESUPRA Posted July 21, 2018 Author Share Posted July 21, 2018 Yes all genuine parts. True could be still air left or vacuum lines loose or damaged. Will hopefully give it another try on my days off and hope it works lol. Quote Link to comment Share on other sites More sharing options...
