Fitting a coolant bleed valve?
evinX
Im going to be redoing my engine bay heater hoses at the rear of the engine, and while im at it, i want to fit a bleed valve to one of the hoses. Just a nice little touch to make life somewhat more simple, What i dont know is....do i fit it to the Inlet or Outlet hose?
https://s26.postimg.cc/eegp11ft5/DIAGRAM.png
https://s26.postimg.cc/ucper62bd/s-l500.jpg
cheers, Kev
An airlock issue is created on GE engine when the radiator top hose is not fitted in correct position.
it's a bit hard to install it in the wrong position? its just 2 clamps and the hose is shaped. Long as its level its fine?
I have come across this time and again.
If the wonk in the hose is not positioned to have the highest portion at the top, the rad/head won't/can't bleed, unless you jack the front high into the air.
Hey ho. :shrug:
My system is fine. I get hot air if needed. Just adding some more blue hoses in the bay. So while the supra is self bleeding. Fitting a nice bleed valve in the rear hoses wont hurt. Better than removing the cap and getting overflow when its just me doing it.
Kev opens valve. Air comes out...then a drip of coolant. Lock the valve. Kev bled the system :D
Outlet hose it is.
To be fair, when I had an oem rad, it bled up easily (before adding any extra bleed points in).
When I swapped to an alloy rad, the problems started. Not sure if it's coincendence, but my heaters have never been as hot as they used to be.
/QUOTE]
Mine went luke warm for a while. After much checking i didnt do the obvious first. Got a new oem cap from toyota. Bled the system. All was good. Maybe your alloy rad and cap arnt agreeing? Any light coolant marks around the cap neck?
Funny you should say that, as there is - although it never seems to actually be wet and leaking.
I think the rad I've got is $#@!, and am thinking of getting a new oem one
/QUOTE]
I bet the cap isnt sealing. What cap you got? Could be the end to your luke warm rad
