John GT Posted July 17, 2018 Share Posted July 17, 2018 Hi there, have my stock TT parked up in the shed at the moment. When I go out and start it up every odd weekend there's a puff of smoke(not blue/white more clear) coming from the turbos themselves. If I turn the car off straight away and back on there is no smoke second time around. There is a smell of fumes from the puff of smoke if this makes sense. Would anyone have experienced something similar, it's like there's something seeping into the turbos/piping when it sits up. Thanks for any help ! Quote Link to comment Share on other sites More sharing options...
bonus_2000 Posted July 17, 2018 Share Posted July 17, 2018 If it is after it has sat for while it could be valve stem seals. Mine used to do the same before I rebuilt the engine. Quote Link to comment Share on other sites More sharing options...
Tyson Posted July 17, 2018 Share Posted July 17, 2018 So the smoke comes out of the engine bay is what you are saying from the actual turbos ? Quote Link to comment Share on other sites More sharing options...
John GT Posted July 17, 2018 Author Share Posted July 17, 2018 So the smoke comes out of the engine bay is what you are saying from the actual turbos ? Sorry didnt make that clear, yeah it comes from the turbos in the bay itself. Valve stem seals are possible as it has sat idle for a good chunk of its life Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 17, 2018 Share Posted July 17, 2018 Blowing manifold gasket? Quote Link to comment Share on other sites More sharing options...
John GT Posted July 17, 2018 Author Share Posted July 17, 2018 Blowing manifold gasket? Yeah that would add up, I'll have to investigate it further. Is there a pipe/rubber hose between turbos that gives trouble too? Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 18, 2018 Share Posted July 18, 2018 As above it must have the common valve stem seal issue but also a gasket leak as the smoke normally comes from the tailpipe. Perhaps its the first decat joint (if it has one?) and the oil/smoke is coming up into the bay so it looks like it's from the turbo's? The rubber pipes won't be carrying the exhaust gases and so I doubt are the source of the smoke, but the two link pipes are worth replacing in the long run if they are original but will not be related to this issue. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 18, 2018 Share Posted July 18, 2018 Sounds like the oil feeds or oil drains to the turbos, assuming stock twin sequential set up is the probable cause. Quote Link to comment Share on other sites More sharing options...
