Swampy442 Posted December 14, 2018 Share Posted December 14, 2018 Which front panel? Quote Link to comment Share on other sites More sharing options...
Tom_K Posted December 15, 2018 Share Posted December 15, 2018 The slam panel. There are pictures of how it’s welded to the sides of the engine bay which the OP was concerned about but imho look fairly standard. Just curious as to how things should look. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 15, 2018 Share Posted December 15, 2018 This is how it should look Quote Link to comment Share on other sites More sharing options...
Chingy Posted December 24, 2018 Share Posted December 24, 2018 I've been reading the forums, and it seems to be a cross of opinions regarding having an after market crank pulley or having a stock one. I understand the benefits of going stock, but what are the cons of having an aftermarket one? It’s not really the issue of after market or stock but more the type of pulley you run and what RPM you intend to run the engine at. You should run a Dampened pulley as Mikeekim89 said this is to reduce vibrations travelling through the crank and causing damage to the engine...crank, bearings, seals etc.. The stock Pulley is a Dampened Pulley and you can get after market pulleys that are also Dampened such as ATI/Titan which dampen using rubber like bushes and can be serviced however the V1 needs a larger belt and machining to fit your crank. Or the Fluidampr one which doesn’t use rubber bushes but is a one piece dampener. The difference over stock is that people running big horse power at higher than stock RPM have reported that the stock pulley can separate, so rather than leave the question they fit an aftermarket pulley as mentioned above. Now you do have a aftermarket pulley but being solid metal this will not dampen so put a Dampened pulley stock/aftermarket on your wish list. Hope that helps and welcome to Supra ownership Quote Link to comment Share on other sites More sharing options...
