SupraGTO Posted July 12, 2018 Share Posted July 12, 2018 (edited) Hi guys, new owner of a 93TT AT which I thought got for a bargain. Just had an inspection done on the car and here are some problems with it. Any advise on the cost and difficulty of repair or have I just bought a lemon? 1. Previous front damage, radiator support was replaced, apparently no frame damage? Looked like some places were welded together. Pretty worried about this. 2. Tranny/Power steering Leak 3. Undercarriage rust That was pretty much all in the report, well, other than the heater was not working (was actually removed, don't need it). Some mods that came with it, that I know of: - HKS full exhaust d-cat system - Calsonic Radiator - Tom's ECU - HKS air filter - FMIC - RE30 18" - Updated lights Edited July 12, 2018 by SupraGTO (see edit history) Quote Link to comment Share on other sites More sharing options...
AC93 Posted July 12, 2018 Share Posted July 12, 2018 Looks like it had a hit. Should be fine as long as all the panels and brackets line up, I’ve seen others have headlight frame sections welded in before Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 12, 2018 Share Posted July 12, 2018 Probably not a PS leak, more than like cam/crank seal, and that lightweight crank pulley would have to go. Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 12, 2018 Share Posted July 12, 2018 You have an after market crank pulley on it that I'd advise you change for a stock damped one. You could have a weeping front crank seal. The area needs a good degrease and then inspection with the engine running to try and identify if its power steering fluid, oil or both. On the plus side it looks (from the dirty attached to the leaking stuff) like it's been weeping a while rather than sprung a major/worrying leak (by this I mean possibly if you'd used it without looking underneath then you might not have noticed anything for some time) Did it have the plastic engine undertray on it - was this removed for the photos? It doesn't look too bad on the face of it given you think you got it cheap. Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted July 12, 2018 Share Posted July 12, 2018 How much did you pay? Quote Link to comment Share on other sites More sharing options...
SupraGTO Posted July 12, 2018 Author Share Posted July 12, 2018 Thanks guys! Great valuable info there! Previous owner kept mentioning it's nothing major and that it'll be able to hold itself up without repairs, but I don't really trust him. The inspection did not specify any frame damage except for the front radiator support, I do suppose the brackets still line up. It is a 25 year old I guess, not expecting an accident free car, just worried it's something major. Thanks for the feedback! I've been reading the forums, and it seems to be a cross of opinions regarding having an after market crank pulley or having a stock one. I understand the benefits of going stock, but what are the cons of having an aftermarket one? It does not have an undertray. Owner says it was removed as it's mainly driven on highways and it doesn't snow here. I reckon' there's plenty of things leaking underneath, just not particularly apparent. I think you're right on the crank seal, would have it looked at. All these seem like pretty hefty repairs. I'm not sure how much these MKIV are going for privately, but I got it for just under £10k, would you guys say its a good buy? Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted July 12, 2018 Share Posted July 12, 2018 My mate bought a tt auto for £950 so not the cheapest in the world Quote Link to comment Share on other sites More sharing options...
SupraGTO Posted July 12, 2018 Author Share Posted July 12, 2018 Wow... £950? I stand defeated. Guess I overestimated the value. Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted July 12, 2018 Share Posted July 12, 2018 Wow... £950? I stand defeated. Guess I overestimated the value. No he was very very lucky Quote Link to comment Share on other sites More sharing options...
Annabella Posted July 12, 2018 Share Posted July 12, 2018 It will be fine, the rust just looks surface, have a look under the hockey sticks at the back and any body kits. Quote Link to comment Share on other sites More sharing options...
mikeekim89 Posted July 13, 2018 Share Posted July 13, 2018 Cons of a non dampened crank pulley are youll kill bottom end bearings needing a bottom end rebuild if your lucky or a new crank/engine. Being a TT no cheap replacement.. this is due too them being improperly balanced and putting alot of undue stress and vibration through the engine. I know this from experience having done my previous engine the same way.. Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted July 13, 2018 Share Posted July 13, 2018 Cons of a non dampened crank pulley are youll kill bottom end bearings needing a bottom end rebuild if your lucky or a new crank/engine. Being a TT no cheap replacement.. this is due too them being improperly balanced and putting alot of undue stress and vibration through the engine. I know this from experience having done my previous engine the same way.. I had one for 3 years with no issues Quote Link to comment Share on other sites More sharing options...
el_bandido Posted July 13, 2018 Share Posted July 13, 2018 My mate bought a tt auto for £950 so not the cheapest in the world Was it red.... Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted July 13, 2018 Share Posted July 13, 2018 was it red.... silver Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 13, 2018 Share Posted July 13, 2018 I had one for 3 years with no issues Doesnt make it right Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 13, 2018 Share Posted July 13, 2018 I'm not sure how much these MKIV are going for privately, but I got it for just under £10k, would you guys say its a good buy? Id say you've had your pants pulled down! I thought you were paying 3 or 4 grand lol. Needs a good deal of work mechanically and cosmetically to bring it up to scratch IMO. And as for crank pulleys, people generally fit solid ones because theyre too tight/poor to pay for a genuine one. Just google harmonic dampers, theyre fitted for a reason Quote Link to comment Share on other sites More sharing options...
Scooter Posted July 13, 2018 Share Posted July 13, 2018 Id say you've had your pants pulled down! I thought you were paying 3 or 4 grand lol. Needs a good deal of work mechanically and cosmetically to bring it up to scratch IMO. I wouldn't say that, find any TT for less? And is he in Hong Kong as per his location? possibly not much choice out there? Anyway you've got it now, the no undertray is ok, I mentioned it as if it had one they can hide quite a leak if they have there padding on them, without one the leak would be apparent everywhere is parked if severe, so the leaks are more likely weeps if you see what I mean. Quote Link to comment Share on other sites More sharing options...
norman1979 Posted July 14, 2018 Share Posted July 14, 2018 I thought you were going to say 3-4k Its a fair price but depends if your still in HK or not Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted July 14, 2018 Share Posted July 14, 2018 (edited) Doesnt make it right Running aftermarket parts doesn't make it right but it works Edited July 14, 2018 by Harrypm82 (see edit history) Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted July 14, 2018 Share Posted July 14, 2018 I was expecting about 3/4k to but I guess in the market that's not bad. Quote Link to comment Share on other sites More sharing options...
Pete Posted July 16, 2018 Share Posted July 16, 2018 It's just got to that point where you'll struggle to find a Supra that doesn't need a few things done to it unless it's been looked after by a real enthusiast. Many ended up in the hands of people that couldn't afford to properly maintain them, whilst others are starting to get rust and need a good refurb. I'd say if the body and interior are OK and you're happy with the buy then it's good. There's always someone that'll say "too expensive" Quote Link to comment Share on other sites More sharing options...
supra_1993 Posted July 17, 2018 Share Posted July 17, 2018 How much are MK4s going for in the UK? Over in the states even the NAs are going up. I don't think you can get a running one for under $18k. Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 17, 2018 Share Posted July 17, 2018 How much are MK4s going for in the UK? Over in the states even the NAs are going up. I don't think you can get a running one for under $18k. 18k uk you can have my near perfect TT aero bpu... Quote Link to comment Share on other sites More sharing options...
supra_1993 Posted July 17, 2018 Share Posted July 17, 2018 18k uk you can have my near perfect TT aero bpu... Oh wow, so much cheaper over seas. Quote Link to comment Share on other sites More sharing options...
Tom_K Posted December 14, 2018 Share Posted December 14, 2018 Bit of a thread revival here but I'm curious for future reference; That front panel with the images of the spot welds, that looks like fairly factory panel joining to me, or is that not how these are assembled? Quote Link to comment Share on other sites More sharing options...
