Overheating problem
Bender
Hi week ago when temp outside reach extremly high my supra start overheating i manage with one 15 minute stop (for cool down) get back home. As i been aware my old water pump was on its way (start leaking) so to get things right today with mu brother in law change water pump (geniue toyota) thermostat and also as i was planing that for months new mishimoto rad put the new coolant and its still the same...what we find out the botom pipe (that one which goes straight to water pump) its cold and top one its quite hot. Its is possible that new thermostat failed ? Or there is something else we can look for ?
Wysłane z mojego SM-G950F przy użyciu Tapatalka
Did you test the thermostat before fitting? Is the system bled? Heater on full and rad cap off?
We didnt test thermostat before fitting [emoji53] system bled(hope so ) heather on full and rad cap off
Did you drive the car around before testing the upper and lower rad hoses? Sometimes just having the car idling and bleeding won't get the thermo completely open. I normally get the system bled, then go for a quick drive then check the operation of thermostat.
If the thermostat hasn't opened you can't bleed the system, are you getting piping hot air out the heater
with it on max heat
I raise the rpm if stationary bleeding to help get the temp up to open the stat, with the rad cap off and full
its obvious when the stat opens as the level instantly drops then you can top it up and bleed the system
with heater on max hot
with it on max heat
Yes it gets piping hot out of the rad. Strange thing i put my heater on max but i only get cold air even if car catch the right temp
Yes it was working perfectly fine
Think you need to check the stat is opening, the system should self bleed itself as long as you have the
expansion tank connected to the rad with a working rad cap
What temp rating is the stat you fitted ? should be 82c i think
What pressure rating is your rad cap ?
Everything its connect as it should i keep toping up expansion tank. Rad cap its from mishimoto as well 1.3 bar did it should be open or close durning the procedure ?
