Durandal Posted July 2, 2018 Share Posted July 2, 2018 So according to toyodiy this is the part number that should should be the IACV VSV But this is what I took off my car. Looks more like the EGCV VSV part. Or are these basicly the same anyway? Quote Link to comment Share on other sites More sharing options...
SupraTRD_MK4 Posted July 3, 2018 Share Posted July 3, 2018 In the 1st diagram using another website which I believe is more updated depicts that part you have selected as p/n 25860-46060 Can you probably post a pic of where exactly it came off? According to your title post it is the IACV next to the exhaust side cam cover. So it is that part number I have given you. I dont believe they are the same as a part from the system they work with differs, the connector from the harness is also different. Quote Link to comment Share on other sites More sharing options...
Durandal Posted July 3, 2018 Author Share Posted July 3, 2018 (edited) It came off the IACV actuator. I'm just wondering if it's the original or someone replaced the original with this, as the part number don't match. Found another thread with the part numbers which mach mine so I guess the toyodiy number is just an anomaly http://www.mkivsupra.net/vbb/showthread.php?331442-VSV-part-numbers-please Edited July 3, 2018 by Durandal (see edit history) Quote Link to comment Share on other sites More sharing options...
Lee P Posted July 3, 2018 Share Posted July 3, 2018 I think the part number is for the valve and the mounting bracket, the part number on the valve is for the valve only. They must have other applications so I wouldnt worry that its different. So the part needed is 25860-46060 as already posted Quote Link to comment Share on other sites More sharing options...
