Wheel spacer advice/ info
Aiden93
Hi everyone,
I’m trying to order some wheel spacers and and I’m a little confused on some of the information I’m required to give. As you can tell wheels, PCD etc aren’t my strong point , the only info I can find out is:
Center bore: 60.1mm
Thread size: M12 x 1.5
PCD: 5x114.3
Aside from that I have no idea about the other info needed. The wheels I have at the moment are Ultralite Nurburgring 18”.
Any info is greatly appreciated 
From (hub pcd) and to (wheel pcd) should be the same (5x114.3) unless you're trying to put wheels with a different pcd on.
- Centre bore is 60.1mm
- stud or bolts option should be studs as the supra hub takes studs rather than bolts.
- threadpitch is correct what u have M12 x 1.5 as far as i am aware
pretty much the same for the wheels side of things too.
Im confused you have all the info you need above?
what size spacers you after? I have a set in the garage
Well I’m after some 50mm spacers for the rear as I’m having some Ridox rear arches fitted in a few weeks, have talked to a few people and since I won’t be tracking the car hub centric spacers should be fine.
