Losing boost on down shifting and slow ramp up
Durandal
So after searching I have found that several people have had the same issue I seem to be having. Boosts fine if you WOT in first or second and shift through gears but down shifting or very gradual ramp up of RPM yields low boost to around 0.4 bar then drops off at around 3800 RPM when the sequential stuff kicks in. I tested the IC piping with a can of spaghetti and ended up launching it across the garage. I've read through Ian C troubleshooting post and some others who have found split hoses.
I bought a pressure/vacuum tester and manually tested all my actuators which seem to be working and used an ohm meter and 12 v supply on the VSV they all check out fine as well. So I put the car in TTC temporarily and it boosts great all the time when it is supposed to. The next day I checked and the EGCV and IACV actuators are still wide open so my pressure tank should be in good working order as well.
Today I disconnected the hose marked with the pink arrow and used my hand pressure pump to build up to 1.1 bar. The EGBV opened and it very slowly dropped off to 0 bar (10 minutes or so). Felt around all the hoses fed from there and could not feel or hear any air leaking. Is that normal?Testing.png
Update re-checked some things again and it seems the IACV VSV is intermittently reading open so looks like a bad coil. So will need to order one of those and see if it fixes the problem. While testing EGCV VSV i also noticed the WG VSV is also bad although I am using a boost controller solenoid so that is not being used anyway.
While waiting for VSV to arrive I figured I'd check some other things
No1 turbo pipe quite choked off. Probably why the No1 turbo always made a higher pitched noise.
Do people bother replacing these with stock ones again or get a different style pipe coupling? I can probably get a some 2 inch hydraulic hose which I'm sure would hold up in the vacuum environment.
Edited by Durandal (see edit history)
  • 3 weeks later...
Just updating this in case someone stumbles across similar issues with the search function. After installing new inlet link pipes to the turbos and a new IACV VSV, the car seems to be working properly in sequential mode now. On down shifts both turbos kick in.
