jza800 Posted June 27, 2018 Share Posted June 27, 2018 if i take the tc and e1 i get error code 63 und 64, cant seems to find the faultcode anywhere.. it is a tt 6 speed j-spec can you help??? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 27, 2018 Share Posted June 27, 2018 If you click on the Blue hyperlink in your post you should be taken to the information you require. Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 27, 2018 Author Share Posted June 27, 2018 nope.. cant find error code 63 or 64 i have reset the ecus, and fault stays away for a while, then comes back??? Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 27, 2018 Share Posted June 27, 2018 Was it originally an auto? Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 28, 2018 Author Share Posted June 28, 2018 No 6 speed Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 28, 2018 Share Posted June 28, 2018 No 6 speed That is strange, I believe those fault codes are for the auto box. Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 28, 2018 Share Posted June 28, 2018 Does this thread (or the linked thread within it) help? http://www.mkivsupra.net/vbb/showthread.php?61679-Error-code-63-amp-64 It does seem to indicate autobox stuff. Is the code you are reading from the flashing engine warning light or flashing slip/OD light? Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 28, 2018 Share Posted June 28, 2018 Your VIN definitely says V160 on it not A340? Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 28, 2018 Author Share Posted June 28, 2018 Yes vin says v160. It is the slip con off that blinks the code. When i takes tc and e1 i can flash the code out, as same way as you do engine truble code. Quote Link to comment Share on other sites More sharing options...
Scooter Posted June 28, 2018 Share Posted June 28, 2018 The trouble is as previously mentioned by Frank the link points towards errors with the solenoid valves in the autobox. If you have a manual and it looks like it is from the factory (tiny chance of an auto loom/engine swap before you got it?) then I wonder if there is a unused plug from the loom and that somehow (time corrosion etc) this is throwing a message even though not used. Reading that is sound like nonsense but the errors you are getting don't seem to fit in with a manual car!? Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 28, 2018 Author Share Posted June 28, 2018 Hmm if you look at this thread Ian c mention error code 63 und 64 as wheel sensor rear??? Quote Link to comment Share on other sites More sharing options...
jza800 Posted June 29, 2018 Author Share Posted June 29, 2018 http://www.mkivsupra.net/vbb/showthread.php?210087-ABS-Warning-light-help-please/page3 Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 29, 2018 Share Posted June 29, 2018 Resurrect. I just found a load of service manual PDFs out there on that thar interweb. They cover the facelift Supra as well, to a point. And while perusing I found that the ABS and TRAC ECu error codes have a 63 and 64: 63 Right rear speed sensor circuit 64 Left rear speed sensor circuit "When the brake switch is OFF, one of the symmetrical wheels’ speed becomes one eight or less of the slowest speed of other 3 wheels continuously for 10 sec. or more." I think that translates as one wheel appears to be going markedly slower than the other three for 10s or more. The fix is basically to check the wiring, connectors and sensors. I'll get the PDFs uploaded at some point -Ian You have your answer then Quote Link to comment Share on other sites More sharing options...
