mac79 Posted June 25, 2018 Share Posted June 25, 2018 Hi All I have just purchased 96 UK Spec headlights to fit to my 93 J-spec I have heard i need to change low beam bulbs? I have HID's fitted so is it just the side lights i need to change? Looking at the back they have an extra unit, I assume that's for the adjustment in the car which the J-spec does not have. Do i need to do anything with that? Thanks Mac Quote Link to comment Share on other sites More sharing options...
mattdavies Posted June 25, 2018 Share Posted June 25, 2018 I seem to remember when I did my swap from J-spec to UK it was very straight forward and I used all the J-spec loom / bulb holders. I would suggest do it with time to pop to an auto factors for bulbs if needed. I have left my adjuster blocks on the back and use the plastic adjusters for adjusting the beam Quote Link to comment Share on other sites More sharing options...
mac79 Posted June 25, 2018 Author Share Posted June 25, 2018 I seem to remember when I did my swap from J-spec to UK it was very straight forward and I used all the J-spec loom / bulb holders. I would suggest do it with time to pop to an auto factors for bulbs if needed. I have left my adjuster blocks on the back and use the plastic adjusters for adjusting the beam Thanks Matt so I can just leave the adjuster block on the back, thats good to know. I might have to change the HID bulb from a HB3 to HB4 which i will order this afternoon. Quote Link to comment Share on other sites More sharing options...
