Problem fitting facelift rears
bayside_supra
Hi guys
Can anyone help me with this problem? I bought some facelift tail lights. I thought they would be easy to fit but seems nothing ever is.
When I plug them in they light up wrong;
The indicators light up the reverse lights...
The reverse lights light up the indicators...
I also only get one red light each side where on my old lights I got all four?
The other thing I’m not sure about is how to rewire in my rear fogs on this button image
This is how they are set up on my old prefacelift lights and they are the 2 inner red lights. What do I need to cut and split into on the facelift looms?
Assuming I can get them working obviously! And no you cannot swap the bulb holders over they do not fit [emoji23]
Any help would be great
Edited by bayside_supra (see edit history)
First of all, those looms are in a horrendous state, and won't be helping anything. Didn't you receive new ones with your facelift lights? Those horrid scotchloks need to go ASAP (those red plastic connectors) they are terrible things at the best of times, but you can see the wires in them are corroded.
When you say "When I plug them in they light up wrong; The indicators light up the reverse lights", do you mean that when you turn the indicators on, the reverse lights come on as the reverse lights normally would, or are the reverse lights flashing?
Always start with the easy stuff - are you sure you have the bulb holders in the correct place on the lights? IE, are the looms mixed up or installed backwards?
