Tailgate glass
shervin_ice
I have a glass here but know idea on the heater elements, is there a way of testing it?
Right you need to connect right side terminal from bottom of the class to the battery positive side and put bulb tester on the negative side and with the tester check the element lines to see if your bulb tester light up it means they are okay
