Cold starts engine running rough ?
herbiemercman
Hi Guys, Recently my engine is running really rough on cold starts, it seems to be over fuelling and you can smell petrol, when i rev it up for a few seconds it runs perfectly and drives well.
I am now at 2 years and 2,500 miles from my single turbo conversion, could the problem be caused by some sort of temperature sensor, i ask this as something must be telling the ECU to dump too much fuel in ? Any help will be appreciated. Herbie.
Hi Guys, Thankyou for your quick reponse, Scooter, yes it could be the temp sensor,this is the first thing i will check out, yes i have the "Emange" piggy back on the stock ECU. Mike2jz the spark plugs were changed at the single turbo conversion for a compatible type.
Swampy yes i am single turbo.
When the engine warms up the tick over is perfect and so is the performance. Does anyone have a schematic diagram of the cold start fuelling system? Herbie.
Hi Guys, Problem solved i thought i would examine closely all the vac pipes and i found one split at the end where it joined the plastic "T" piece, i cut the end off and reconnected it, i am not sure were it terminates apart from seeing one end connected to the air intake manifold. see pici. Engine now starts as it used to fast tick over smooth, then in 5 mins cold start goes off and perfect tick over. It is great when some things are quick and easy, i thought i was about to start a diagnostics walk in the fog, so i am reet chuffed.
Thank you all for helping. Herbie.
