BPU TT Auto with Mines ECU
mattdavies
Engine Type - 2JZ-GTE
Engine Spec - Stock
Turbo - Stock Twins
Fuel Used - Shell V-Power
Exhaust - 3” Decats and Blitz Nur Spec
Transmission - A340 Auto
ECU - Mines
Dyno Used - Surrey Rolling Road
Power figure - 416bhp at Fly
Torque figure - 380ft/lb
Boost Pressure - 1.2 Bar
Hello there Matt. Can you tell me what has the ECU helped you with? I am assuming if you have increased the boost, it should prevent the ECU from cutting the fuel unless you have achieved that with the direct power supply mod but I am unsure of how that works currently. I too have the same spec car as yours and only recently did I acquire my engine which will require a rebuild. I have the std Auto TT ECU and Throttle ECU and I too have a MINES plaque on the main ECU.
  • 1 year later...
  • 2 months later...
