Mgrene Posted June 8, 2018 Share Posted June 8, 2018 (edited) Evening Forum. Can anyone tell me the function of the two lines (not the fuel feed and return)? Any way to check that they are fully functional? Edit: one is attached to the hanger, the other is the one on the right side attached to the fueltank. Edited June 8, 2018 by Mgrene (see edit history) Link to comment Share on other sites More sharing options...
Mgrene Posted June 8, 2018 Author Share Posted June 8, 2018 Link to comment Share on other sites More sharing options...
evinX Posted June 8, 2018 Share Posted June 8, 2018 One is main feed...one is to the canister...and ine is return. All 3 have a main function. Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 8, 2018 Share Posted June 8, 2018 Edit, beaten to it. See above. Link to comment Share on other sites More sharing options...
Mgrene Posted June 8, 2018 Author Share Posted June 8, 2018 Canister? Sorry I struggle some times with the language. Can you specify what the canister is? Link to comment Share on other sites More sharing options...
Frank Bullitt Posted June 8, 2018 Share Posted June 8, 2018 (edited) Charcoal canister that is under the bonnet. Yours may have been removed already. See here - http://www.mkivsupra.net/vbb/showthread.php?295530-Removing-the-Charcoal-Canister&p=3722526&viewfull=1#post3722526 Edited June 8, 2018 by Frank Bullitt Link added. (see edit history) Link to comment Share on other sites More sharing options...
Mgrene Posted June 8, 2018 Author Share Posted June 8, 2018 (edited) I just did some searching on the TSRM app. I understand now that the hoses are respectively called Fuel breather hose (monted on the fuelhanger). Evap hose (mounted on the tank). By the looks of it, the breather hose goes to the location where you fill fuel to your car. The Evap hose must be the one that goes to the canister that you are talking about. Where under the bonnet can I find it? The reason why I’m asking questions of this, is because there is building a lot of pressure in my tank and I suspect that either the breather hose or the Evap hose doesn’t function. Edit: just saw now that you added a link. Only problem is that my car is highly modified so that canister is not there any longer. Edited June 8, 2018 by Mgrene (see edit history) Link to comment Share on other sites More sharing options...
