bignum Posted June 7, 2018 Share Posted June 7, 2018 New or used, not fussy. Link to comment Share on other sites More sharing options...
jagman Posted June 8, 2018 Share Posted June 8, 2018 Could you not fill the voids of a stock one or existing one with polyurethane? ie make your own Link to comment Share on other sites More sharing options...
jagman Posted June 8, 2018 Share Posted June 8, 2018 http://www.suspension.com/blog/do-it-yourself-liquid-urethane-motor-mount-replacement-inserts/ Link to comment Share on other sites More sharing options...
bignum Posted June 8, 2018 Author Share Posted June 8, 2018 Interesting, great idea thanks, i`m all about diy bud. Link to comment Share on other sites More sharing options...
jagman Posted June 8, 2018 Share Posted June 8, 2018 It works - and it's cheap , I'm doing an engine mount on my Audi , next week , I use aircraft fuel tank sealant , type of non silicon rubber , everything proof ,and tough as old boots - downside is once it's on ,it's a mare to get off , hands , clothes and anything it touches - I have plenty if you want a tube (work skip them once lifex) but they still have about 50 years before they are unusable - lol Come in a kit for a normal skeleton gun , push a plunger in pump handle which pushes the hardener in , then pump for two mins to mix and then into your gun and away you go ... 24 hours to cure Link to comment Share on other sites More sharing options...
bignum Posted June 8, 2018 Author Share Posted June 8, 2018 sounds ideal, i`ll pm you later mate, thanks Link to comment Share on other sites More sharing options...
