Scooter Posted June 6, 2018 Share Posted June 6, 2018 Does anyone use any sort of rubber matting for working on the drive/ in the garage? I'm thinking of getting some ribbed stuff as I want to lay it on a sloped area and have any rogue fluid spillage flow to one side and not all over the place (the ultimate aim is to keep the surface clean, so lay this down, carry out work, tidy up and roll up/put away). Thinking of a 2m wide roll but depending on length/thickness it's quite expensive and so looking for advice, ie will 3mm thick just get chewed by a jack? 6mm thick to heavy to roll up move, perhaps go thin but add some carpet in top? Quote Link to comment Share on other sites More sharing options...
