Bender Posted June 4, 2018 Share Posted June 4, 2018 Hi guys i need a bit of help. Today my Supra start generating strange noises when i try to move from 1st gear or reverse. The noise its quite loud and it sounds like back of the car will go apart. I check the car but everything seems ok. Any idea what i can look for ? Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
rider Posted June 4, 2018 Share Posted June 4, 2018 It would be useful if you can expand a bit. Does the car move or just make noise when you engage the clutch and not move? If you can raise the back on axle stands and have a co-pilot put it into gear and go through the gears that could help you identify specifically where the noise is originating from and from that the probable part that is broken or breaking. Link to comment Share on other sites More sharing options...
Bender Posted June 4, 2018 Author Share Posted June 4, 2018 rider said: It would be useful if you can expand a bit. Does the car move or just make noise when you engage the clutch and not move? If you can raise the back on axle stands and have a co-pilot put it into gear and go through the gears that could help you identify specifically where the noise is originating from and from that the probable part that is broken or breaking.Yes car moves and drives its just that terrible noise...not every time. Its start make a noise when i start moving Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
squiffy Posted June 4, 2018 Share Posted June 4, 2018 Sounds like you may have killed the diff? Link to comment Share on other sites More sharing options...
Bender Posted June 5, 2018 Author Share Posted June 5, 2018 Been at mechanic today they said diff is gone i put video in post what do you thinkhttp://cloud.tapatalk.com/s/5b166c2358687/20180605_110725.mp4 Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
rider Posted June 5, 2018 Share Posted June 5, 2018 There is a lot of slack in that drive. Its easy enough to drop and take the casing apart to have a look but I'd start checking the classifieds. Link to comment Share on other sites More sharing options...
Bender Posted June 5, 2018 Author Share Posted June 5, 2018 rider said: There is a lot of slack in that drive. Its easy enough to drop and take the casing apart to have a look but I'd start checking the classifieds.I already did but theres nothing yet [emoji21] Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
Bender Posted June 11, 2018 Author Share Posted June 11, 2018 Ok so quick update it was the diff. Wysłane z mojego SM-G950F przy użyciu Tapatalka Link to comment Share on other sites More sharing options...
