Drop links Alternative?
Jellybean
The drop links on the car are around 2K miles old , I can count on onw hand how many times it was used in the rain and never in snow,winter...
Are the OE items a poor design , using an allen key to prevent the stud from spinning so you can crack loose the nut
Other than covering them in ACF50 or covering them some how , is there a better design out there?
At what point would you require Adjustable drop links?
I got febi bilstien oem spec ones on mine...been on for a few years with no issuse. Well prices and good build quality. We just put a full set on our celica also as opposed to buying new from toyota.
When removing old ones i always have to end up splitting the nuts to get them off. If yours are on 2k miles the alen key fitting should be near new in therr
