Traction control light and overdrive light Blinking with no speedometer
Dudebug74
So I dont know were to go next. So my speedometer does not work, odometer turns on but does not move, the overdrive light blinks but overdrive works ,then the manual button does not work, and the orange traction control light blinks but does not work. I have put it back to stock I removed the speed limiter and the converter for changing from km to miles. Also i removed my turbo timer just in case still didn't change anything. I have also tried a new ECU and replaced Speed sensor #1 and #2. The car runs fine and shifts fine. Don't really know where to go from here anything could help. My car is a 93 Auto TT.
Seems to be cropping up quite a lot this does.
I have similar fault after hitting a pothole. Littlenum checked mine over and couldn't find a fault anywhere else. When he opened my main car ecu he thinks it looks like i have couple of leaking capacitors which could be causing it. We're waiting for an ecu to borrow to see if it cures it.
