Changing the cam cover gaskets - no Seal packing 08826-00050
monkey3
Hello all,
Just changing the cam cover gaskets as one of them is a tiny bit weepy and buying up the parts to do it...
So apparently this (Seal packing 08826-00050) part has now been discontinued.
Now I wouldn't normally worry about this and I'd just use the closest sealant to hand but with my new Sup being something of a nice one I wondered what the best replacement to use would be.
*I need to keep it nice and original as far as possible.
Thanks for any ideas
:thumbs:
Some suggestions here....
http://www.mkivsupra.net/vbb/showthread.php?345311-Valve-cover-gaskets-Silicone&highlight=silicone
This stuff is grey (which I think is the oem colour?)
Henkel Loctite SI 5660 Premium Grey Silicone
100ml
High flexibility gasket maker
For flanges with permanent water/ glycol contact
Excellent coolant resistance and very good oil resistance
OEM Specified by many Japanese manufacturers
Temperature Resistance: -55°C to 200°C
This 100ml tube of premium grey silicone sealant is for flanges of any size and shape. Typical uses include water pump, thermostat, oil sump, valve cover, inlet manifold etc...
We also sell a low flexibility black silicone recommended for general purpose use and a copper silicone recommended for high temperature uses.
All our products are provided direct to us by the manufacturer. They are in date and in perfect condition.
We also stock a wide range of other Henkel products. We can recommend a suitable product if you are unsure.
Edited by Scooter (see edit history)
I think you are slightly over worrying if you want to keep two blobs of sealant by the cam caps original ;) :D but I'll have a look what's recommended :)
lol.
Yeah, it was more for the receipts and things to show that it was done properly with original parts and so on.
100ml
Brilliant! thanks.
Now where is that search button???
:innocent: :search:
:spank:
Where did you get it in the uk?
I can see it's on ebay from a "new seller" but I can't find it readily anywhere else...
US Auto on ebay
https://www.ebay.co.uk/itm/Permatex-82180-RTV-Silicone-Ultra-Black-Gasket-Maker/281419968206?epid=679555857&hash=item4185efeece:g:DwMAAOSw~OdVevIA
Quite fast on postage, its 4.50 postage there and will more than likely get it by saturday
