far Posted May 30, 2018 Share Posted May 30, 2018 HI All thinking about using these guys https://www.stencil-tech.co.uk/ some people are saying stay awa etc, others seem to think if its done properly its good. what do you guys think? Driveway is circa 1100 sqm - is it ok to do a space this size? There used to be some good trades people on here a while back so I thought I'd ask the question. Link to comment Share on other sites More sharing options...
chazuk Posted June 1, 2018 Share Posted June 1, 2018 I looked into it but if you search there are lots of reviews from people that have had it done granted from different companies but it gives you a idea https://forums.moneysavingexpert.com/showthread.php?t=3049636 , https://www.pistonheads.com/gassing/topic.asp?h=0&f=207&t=994643 Have you thought about coloured tarmac http://www.esc-surfacing.co.uk/coloured_tarmac.html Link to comment Share on other sites More sharing options...
Al Massey Posted June 1, 2018 Share Posted June 1, 2018 My parents have had this type of work done. Looks great. No major issues in the process or afterwards. Needs resealing every couple of years for a cost of about £60. I’ve even worked on the supra many times on the drive with no issues. [ATTACH]227439[/ATTACH] [ATTACH]227440[/ATTACH] [ATTACH]227441[/ATTACH] Link to comment Share on other sites More sharing options...
blythmrk Posted June 1, 2018 Share Posted June 1, 2018 Coloured tarmac is absolute rubbish (I presume you mean the resin type) There is one of the major suppliers of patterned concrete materials near me called pics concrete (they are a nation wide company) maybe contact them and they may recommend somebody near you? Link to comment Share on other sites More sharing options...
chazuk Posted June 1, 2018 Share Posted June 1, 2018 Coloured tarmac is absolute rubbish (I presume you mean the resin type) There is one of the major suppliers of patterned concrete materials near me called pics concrete (they are a nation wide company) maybe contact them and they may recommend somebody near you? Really you see it in zoo's and football stadiums it's very hard wearing ,water does not lay on the top as bad as it does with concrete and no way near as slippery Link to comment Share on other sites More sharing options...
blythmrk Posted June 1, 2018 Share Posted June 1, 2018 Really you see it in zoo's and football stadiums it's very hard wearing ,water does not lay on the top as bad as it does with concrete and no way near as slippery My parents had it a few years ago and it all started breaking up after a few years for low maintenance patterned concrete but I still prefer proper block paving Link to comment Share on other sites More sharing options...
Rob W Posted June 1, 2018 Share Posted June 1, 2018 A few of my neighbours have this, one it has lasted years and the other 6 months and started to crack. Think it all depends on who you use. We have block paving but obviously more up keep and out lay but 15 years on and still sound. Link to comment Share on other sites More sharing options...
far Posted June 8, 2018 Author Share Posted June 8, 2018 cheers lads seems from what people are saying on here and other websites it really does depend on who does the job, the highest quote i've had is 98k and the cheapest is 54k Link to comment Share on other sites More sharing options...
jagman Posted June 8, 2018 Share Posted June 8, 2018 Your problem is the size , it will cost a small fortune , not knowing your ground condition or existing drive maybe https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=12&cad=rja&uact=8&ved=0ahUKEwjkwc6q3sTbAhVEyRQKHbseCLYQFghxMAs&url=https%3A%2F%2Fbritishrecycledplastic.co.uk%2F&usg=AOvVaw1HwRb9yhlOnFHLymicZLdR recyled plastic as a base cemented down and top filled with the recycled rubber pellets to finish -rubber crumb https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwj3tMiZ38TbAhUDPBQKHbz9CL0QFggyMAE&url=https%3A%2F%2Fecopaving.com%2Fdriveway-paving-cost%2F&usg=AOvVaw0ZH5Sk0XJaeJt3t08dM-0b Link to comment Share on other sites More sharing options...
jagman Posted June 8, 2018 Share Posted June 8, 2018 Maybe contact a plastic recycler in UK and design your own grid panel , get 1100 done at the depth you need ,after all it doesnt have to outlast the roman roads and you wont see any of it -pour in ready mix once down and rubber top coat in whatever colour you want -I would not go YELLOW , you will only attract Munchkins, tin men ,lions et al every day !!!! Link to comment Share on other sites More sharing options...
keron Posted June 8, 2018 Share Posted June 8, 2018 Stay away from these muppets. My neighbour had it done and had nothing but problems. Very unprofessional. Fred the owner drops 2 or 3 polish workers down your house and leaves them to work all day. They got dust all over my properly, very expensive cars and didn’t cover anything. The crap went everywhere. I’m currently taking them to court over it. Link to comment Share on other sites More sharing options...
jagman Posted June 9, 2018 Share Posted June 9, 2018 It's hard to suggest what to do without knowing the layout , is it drive plus parking and how much drive versus how much parking , lastly the layout you have already is there an existing drive ? The ground work depends on what you have already and so does the cost . I always like to think a bit out of the box - the plastic reinforce grids come in about £8800 , these are fast laying 75sq M per hour , so labour costs reduce , but they are designed for gravel /pebbles infill - relatively cheap and easy I would look at poured concrete into the plastic grids , something like £10000 , but the grid would support the concrete and reduce the need for shuttering and become very strong . Not pretty as its concrete , so leave a top gap of 5 - 10 cm , now you can choose the top layer - gravel chippings (cheap) or the rubber chip in colours , maybe edge in brick . Maybe a higher spec in parking areas or near house and lower for access road ? Got to be 20k plus for the rubber layer more if you put complex patterns or logo like supra parking only ! -depends on size As long as a slope for water runoff is added should last decades , whatever you do it's a dear job due size , and finding builders - good luck Link to comment Share on other sites More sharing options...
Havard Posted June 12, 2018 Share Posted June 12, 2018 We had it at our old house. Looked great at first then the surface sealer started to peel off, crack appeared a couple of years later and ultimately looked crap about 5 years down the line. I wouldn't go this route again. I would either go with pebbles / gravel or tarmac with block paving around the edges. H. Link to comment Share on other sites More sharing options...
Wez Posted June 12, 2018 Share Posted June 12, 2018 As above it really depends on who you use, some last ages and show no signs of cracking and others are cracking within a year. Link to comment Share on other sites More sharing options...
Wez Posted June 12, 2018 Share Posted June 12, 2018 Have you looked at resin bonded as another option? Link to comment Share on other sites More sharing options...
Havard Posted June 12, 2018 Share Posted June 12, 2018 Also, it was stupidly slippy on frosty mornings and using salt would have damaged the protection layer. Fell twice on a slight incline over the years and lucky not to do myself a serious mischief...!! H. Link to comment Share on other sites More sharing options...
