vmax330 Posted May 27, 2018 Share Posted May 27, 2018 Hello, I have two parts for sale : -Piggyback HKS F-Con Silver with harness to connect it to your stock ECU, for a JDM BV6 pre-VVTi. It was mounted on my car and removed the 180 KPH speed limiter and 1 bar boost limiter, but there was a little problem : the car was limited to 240 KPH with it. 175 £ + shipment Link to comment Share on other sites More sharing options...
curious Posted May 27, 2018 Share Posted May 27, 2018 Hi, interested in the gauge, any pictures and dies it come with the loom and sensors ? Link to comment Share on other sites More sharing options...
curious Posted May 27, 2018 Share Posted May 27, 2018 Also does the F-Con come with the map and air temp sensors ? Thanks Link to comment Share on other sites More sharing options...
vmax330 Posted May 27, 2018 Author Share Posted May 27, 2018 Hi, I have these pictures, the gauge comes with loom and sensors, butI don't have map and air temp sensors for the F-Con [ATTACH=CONFIG]227339[/ATTACH] [ATTACH=CONFIG]227340[/ATTACH] Link to comment Share on other sites More sharing options...
badboyz00700 Posted May 28, 2018 Share Posted May 28, 2018 Will this work on j spec tt auto non vvti and also would a map and air flow sensor off of fcon pro gold work ? Link to comment Share on other sites More sharing options...
vmax330 Posted May 28, 2018 Author Share Posted May 28, 2018 I'm not sure but I think it won't work on an automatic car. And I didn't have the map and air flow sensor, but it was working well on my car without that Link to comment Share on other sites More sharing options...
curious Posted May 28, 2018 Share Posted May 28, 2018 This is the original F-con V (silver) which works as a piggy back. You can switch it to a stand alone for a set range, but the resolution is too low for it to remove the airmass meter as in a F-con Vpro (gold) successfully. Also very few dealers have the original F-con V software as it wasn't supported by HKS Europe. Hope that helps Link to comment Share on other sites More sharing options...
vmax330 Posted June 3, 2018 Author Share Posted June 3, 2018 Gauge has been sold, F-con still for sale Link to comment Share on other sites More sharing options...
