D1andonlyantman Posted May 26, 2018 Share Posted May 26, 2018 Hi everyone. I'm just wondering what my options are regarding headlight bulbs, HIDs, LEDs etc. I've got a j-spec 98' vvti and coming from a car with decent headlights, night driving is a little scary haha. It's never something ive needed to learn about before, so any advice or pointers would be much appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
jagman Posted May 26, 2018 Share Posted May 26, 2018 You can fit higher wattage bulb in stock - crap You can fit HID bulbs in stock - blue crap You can fit LED in stock - white crap You can fit HID in new projector - now we can see at night You can fit LED in new projector - oh yes You can retro fit new OEM from another modern car (with projector-D2S and such) - just like any modern car - you can see great at night . You can retro for spanking new look round corner matrix lights - but would cost more than a new car . Morimoto projector and bulb and ballast is probably the best cost/performance , or just do nothing and wipe out small mammals at night Quote Link to comment Share on other sites More sharing options...
D1andonlyantman Posted May 26, 2018 Author Share Posted May 26, 2018 Ok mate, cheers for that Quote Link to comment Share on other sites More sharing options...
charlton Posted May 29, 2018 Share Posted May 29, 2018 You can fit higher wattage bulb in stock - crap You can fit HID bulbs in stock - blue crap You can fit LED in stock - white crap You can fit HID in new projector - now we can see at night You can fit LED in new projector - oh yes When you say projector, what is the difference from the stock unit as I thought the lights were projectors anyway, does it require any/much modification? Do you have any links to LED projectors? I could do with a bit more light at the front of the Supe! Quote Link to comment Share on other sites More sharing options...
jagman Posted May 29, 2018 Share Posted May 29, 2018 The stock lights are projectors but the optical performance is poor , newer projectors are much better , it is a bit of a job to replace them , chopping out the originals and bonding in new ones ,(using the same diameter projectors ) - the lights need to be opened up Once the projectors are in any bulb works better Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 29, 2018 Share Posted May 29, 2018 The stock lights are projectors but the optical performance is poor , newer projectors are much better , it is a bit of a job to replace them , chopping out the originals and bonding in new ones ,(using the same diameter projectors ) - the lights need to be opened up Once the projectors are in any bulb works better Intrested in a link to these led projectors as well if poss Quote Link to comment Share on other sites More sharing options...
Dnk Posted May 30, 2018 Share Posted May 30, 2018 (edited) Didn't i read unless the headlight came fitted with HID bulbs it would now be an mot fail to retrofit them Edited May 30, 2018 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Ric Posted May 30, 2018 Share Posted May 30, 2018 TBH HID's in the stock lights are fine and perfectly light up the road. You want 4000k for them just to be white, rather than blue. Yes the MOT rules now make it a bit harder, so you'd probably be better with some 4k LEDS Quote Link to comment Share on other sites More sharing options...
kaz Posted May 30, 2018 Share Posted May 30, 2018 There's always this polarizing option: Quote Link to comment Share on other sites More sharing options...
