Paul372 Posted May 26, 2018 Share Posted May 26, 2018 I have a jap spec auto tt with jap spec speedo clocks, can I swap them over with auto uk spec clocks? Is there anything thing that I have to change and will the speed reading mph work correctly and give a correct reading thanks Quote Link to comment Share on other sites More sharing options...
David P Posted May 27, 2018 Share Posted May 27, 2018 Yes and it's a much better idea than using a speed converter. Best to change just the speedo as the warning lights may be a different spec? Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 27, 2018 Author Share Posted May 27, 2018 Thanks so I can do away with the speedo converter Quote Link to comment Share on other sites More sharing options...
David P Posted May 27, 2018 Share Posted May 27, 2018 For KPH/MPH yes, but if you have OE ECU, you will still need part of it for delimiting max speed. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted May 28, 2018 Author Share Posted May 28, 2018 I still have Oem ecu, I shall give it ago a see what happens thanks Quote Link to comment Share on other sites More sharing options...
