Speedo jumping and fuel cut
Picoto
hey guys need some advise here. so when accelerating my speedo will jump up and down like crazy this has only started when we fitted the delimiter. I have also noticed when cruising around 60 mph at about 2000 rpm the car is cutting fuel as if the limiter is kicking in. any advise would be appreciated thanks guys.
I would start with removing the delimiter and see if it still happens. If so then the delimiter is dodgy or not installed correctly
