Black_Supra Posted May 23, 2018 Share Posted May 23, 2018 Hey guys, got a Jspec TT6 Facelift Supra and yesterday i disassembled the diff. It is broken. Now my question - does a B03B Torsen Diff even fit in the A03B case? Quote Link to comment Share on other sites More sharing options...
AC93 Posted May 23, 2018 Share Posted May 23, 2018 I believe not, someone else should be able to confirm Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted May 23, 2018 Share Posted May 23, 2018 I think the B03B had a 220mm ring gear and the A03B a 200mm. It may be that the diff itself will fit, if the ring and pinion gears are swapped. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2018 Share Posted May 24, 2018 I think the B03B had a 220mm ring gear and the A03B a 200mm. It may be that the diff itself will fit, if the ring and pinion gears are swapped. I don't think you can put the smaller ring and pinion in the bigger case, and you definitely can't put the bigger one in the small case... Quote Link to comment Share on other sites More sharing options...
Black_Supra Posted May 27, 2018 Author Share Posted May 27, 2018 Okay, that means i need a A03B Diff core ... thanks guys! Quote Link to comment Share on other sites More sharing options...
