Guest Ride-or-Die Posted May 21, 2018 Share Posted May 21, 2018 Just wondering whats the best option to go regarding painting calipers. Would it be best to get them sand blasted then powder coated or hand sand then 2pac them? What do the factory companys do? eg brembo etc Also noticed the seals are worn and cracked. Any recommendations what repair kits to use? Any advice would be really appreciated Thanks! Quote Link to comment Share on other sites More sharing options...
Cam27 Posted May 21, 2018 Share Posted May 21, 2018 I have just refurbished my UKs, and sanded them by hand. If you get them blasted you will have to split them as the grit collects inside the channels and Toyota don't sell the gaskets between the two halves (although Chris Wilson might still). I used VHT matt black and the finish is excellent! TCB parts are very competitively priced on the seal kits. Quote Link to comment Share on other sites More sharing options...
Guest Ride-or-Die Posted May 21, 2018 Share Posted May 21, 2018 Thanks cam27 for the info That looks really nice!!! That’s the result I’m aiming for Did you use any primer ? Could you give me a link where to get the repair kit? Quote Link to comment Share on other sites More sharing options...
Cam27 Posted May 21, 2018 Share Posted May 21, 2018 Here is the link for the seal kits, if you click brakes then the green supra icon at the top then scroll down, there is one kit for the fronts and one for the rears http://www.tcbparts.co.uk/ I didn't use primer or clear coat, because of the high temperatures. I applied 3 coats of the VHT to the keyed metal, which then cures at high temps (when the calipers are hot after use). You could use primer if you like, just make sure it has a high temperature rating. This is the paint I used Hope that helps:thumbs: Quote Link to comment Share on other sites More sharing options...
evinX Posted May 21, 2018 Share Posted May 21, 2018 Id invest in a dremel and use that to sand them nicely. Then get some foliatec carbon grey as its close to the oem colour and 2pack. Brush on and levels itself nicely. Tough shiney finish to Quote Link to comment Share on other sites More sharing options...
Guest Ride-or-Die Posted May 21, 2018 Share Posted May 21, 2018 Those are the sprays I got. Should I respray and then repair or the other way around ? Will keep you guys updated with photos Quote Link to comment Share on other sites More sharing options...
Guest Ride-or-Die Posted May 21, 2018 Share Posted May 21, 2018 Is that it??? How do i tell if my pistons are good/bad? Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted May 22, 2018 Share Posted May 22, 2018 I just got some etech paint. just paints paints straight on with a brush and no primer. kit was about £14 with brake cleaner, brush and paint. probably enough for 8 calipers! Quote Link to comment Share on other sites More sharing options...
MRX Posted May 22, 2018 Share Posted May 22, 2018 Just done mine with the etech paint, very happy with the finish. As always, the more effort put into the prep the better the result. Quote Link to comment Share on other sites More sharing options...
Guest Ride-or-Die Posted May 23, 2018 Share Posted May 23, 2018 If my Pistons haven’t sized should I still replace them? Quote Link to comment Share on other sites More sharing options...
Guest Ride-or-Die Posted May 23, 2018 Share Posted May 23, 2018 MRX/Tommy Any photo’s of the results ??? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2018 Share Posted May 24, 2018 If the chrome has pitted on the pistons you are best replacing them. Cheap replacement pistons are gold zinc irridited, or black zinc plated and it wears off leaving bare mild steel, so they rust far quicker than the OE chrome plated ones. For really long life you need stainless steel pistons. I can supply seal kits, stainless pistons, stainless pad pins and the special square shaped seals that go between the caliper halves when you split them to hone the bores. These square seals should NOT be reused! Toyota do not list them. I can supply stainless pistons for UK and Jap spec calipers, as well as for most any caliper off any car that I can have a sample piston for. If you bead blast do NOT allow blasting medium down the caliper half bolt threads. If even a tiny bit remains it will often lock the bolts up on reassembly, and the bolts are a very odd thread / grip length and not available. I can Helicoil mangled ones on a jig on the Bridgeport, and fit a slightly bigger diameter cap head bolts, but it's far better and cheaper not to bugger them up in the first place Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted May 26, 2018 Share Posted May 26, 2018 I did mine last week mate, rubbed them down and I used plasti dip. They came out really good and with the supra decals sets them off. Quote Link to comment Share on other sites More sharing options...
