Lee P Posted May 19, 2018 Share Posted May 19, 2018 Selling on behalf of a customer. Just removed from his 1997 Supra with 76,106 on the clock. Some KM and some miles after import. Would be ideal for a rolling shell Comes with 2JZ-GE engine All ancillaries and mounts Headers and 1st cat Loom and Auto ECU Ignitor Coil Air box, inlet pipe work and air scoops Charcole canister and pipe work Red silicone radiator hoses hoses Auto gearbox (no bell housing bolts) Cooler lines Gearbox mounts Auto gear lever Interior gear lever surround (Clifford button will be removed so will leave hole) Brake pedal Facelift Auto clocks (speedo swapped see below) Prop Starter motor Customer wants to retain his mileage so the speedos will be swapped from clusters. The speedo provided will have the mileage from the manual clocks we are fitting to the car. We have done a running video of the car to show all working. £1200 collected Thanks Link to comment Share on other sites More sharing options...
