Jellybean Posted May 15, 2018 Share Posted May 15, 2018 Hey I changed the Fluid for ATF , turned her on , turned the wheels side to side, to flush out any air , topped up as required Its not a bad whine but she is louder than before , air still in there I presume? Am I missing something Quote Link to comment Share on other sites More sharing options...
bignum Posted May 15, 2018 Share Posted May 15, 2018 Probably some air bubbles yes, leave it overnight then check again, also check any loose hoses. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 15, 2018 Author Share Posted May 15, 2018 No leaks , it’s was driven for a few weeks after and sitting up over the winter since change Quote Link to comment Share on other sites More sharing options...
Gpro Posted May 16, 2018 Share Posted May 16, 2018 how many times have you turned the wheel from side to side? best thing to do is jack up the front and keep turning full lock left and full lock right with the power steering cap off (engine must be off). Do this about 20-30 times whilst keeping an eye on the power steering fluid to ensure it doesn't get too low. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 16, 2018 Author Share Posted May 16, 2018 Thanks , will give it a go Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2018 Share Posted May 24, 2018 Leave it overnight with the reservoir cap off. This allows air to migrate out. I see a lot of PAS issues on the MKIV these days and have gone to some trouble and expense working out their idiosyncrasies that occur in old age. I have also sourced a supply of new PAS pumps that are far cheaper than Toyota, but unlike the Ebay ones do not grind themselves to a paste most of the time, taking the rack with them. They DO need a minor pulley mod though, which I can do. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 24, 2018 Author Share Posted May 24, 2018 Thanks Chris , I might be onto you later in the year about a pump Quote Link to comment Share on other sites More sharing options...
