Pins For block connector -- Heater control unit
Jellybean
Burna , I presume they come with Pins ; you crimp the broken tails with a Heat Shrink Insulated Butt Wire Crimp Connector
I ordered from TCB the Toyota male and female wires that come with the pins already crimped on the end. I don't like using crimp connectors personally, so I always solder wire to wire and heat shrink on the outside after :)
Edited by Burna (see edit history)
Cool , might solder and heat shrink , its a bit tight in there for Butt connectors
I had the same, it was when I was wiring up my Lexus wheel to use the flappy paddles, made up my own little loom with a new plug from Toyota so I could connect it to the Supra clock spring. Not much room behind the airbag at all! Don't want to do that exercise again anytime soon! lol
  • 2 weeks later...
