Jellybean Posted May 14, 2018 Share Posted May 14, 2018 Does anybody know the name of the Pins used ? Pins that click into the Block connector Had a look online but no luck and tried Toyota but they do not do them Quote Link to comment Share on other sites More sharing options...
rider Posted May 14, 2018 Share Posted May 14, 2018 Try female terminal crimp pins. Denso make them, various sizes. Quote Link to comment Share on other sites More sharing options...
rider Posted May 14, 2018 Share Posted May 14, 2018 This is the sort of thing you want. there are two sizes for pins on the a/c controller so you need to figure out what size you are after. Or try talking to Denso Europe, they do field email enquiries. Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted May 14, 2018 Share Posted May 14, 2018 Does anybody know the name of the Pins used ? Pins that click into the Block connector Had a look online but no luck and tried Toyota but they do not do them Sent you a link mate, Toyota still make these despite what they claim. Any problems just shout Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 14, 2018 Author Share Posted May 14, 2018 thanks for the help for Block connector (larger one) 90980-11469 Repair wires 82998–12340 82998–12420 Smaller connector 90980-11556 82998–12420 Quote Link to comment Share on other sites More sharing options...
Burna Posted May 14, 2018 Share Posted May 14, 2018 Yeah I've bought pin and tails before from toyota via TCB parts. Quote Link to comment Share on other sites More sharing options...
rider Posted May 14, 2018 Share Posted May 14, 2018 You might want to read this before ordering from Toyota. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 14, 2018 Author Share Posted May 14, 2018 Yeah I've bought pin and tails before from toyota via TCB parts. Burna , I presume they come with Pins ; you crimp the broken tails with a Heat Shrink Insulated Butt Wire Crimp Connector Quote Link to comment Share on other sites More sharing options...
Burna Posted May 14, 2018 Share Posted May 14, 2018 (edited) Burna , I presume they come with Pins ; you crimp the broken tails with a Heat Shrink Insulated Butt Wire Crimp Connector I ordered from TCB the Toyota male and female wires that come with the pins already crimped on the end. I don't like using crimp connectors personally, so I always solder wire to wire and heat shrink on the outside after Edited May 15, 2018 by Burna (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 14, 2018 Author Share Posted May 14, 2018 Cool , might solder and heat shrink , its a bit tight in there for Butt connectors Quote Link to comment Share on other sites More sharing options...
Burna Posted May 15, 2018 Share Posted May 15, 2018 Cool , might solder and heat shrink , its a bit tight in there for Butt connectors I had the same, it was when I was wiring up my Lexus wheel to use the flappy paddles, made up my own little loom with a new plug from Toyota so I could connect it to the Supra clock spring. Not much room behind the airbag at all! Don't want to do that exercise again anytime soon! lol Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2018 Share Posted May 24, 2018 Raychem makes some beautiful tiny crimp connectors. Adhesive lined, but need a special crimping tool. I use them all the time, so much better than the standard size red ones, which are too bulky for many applications.. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted May 24, 2018 Author Share Posted May 24, 2018 Great thanks , I have so many specialists tools at this stage ; I should open a garage Quote Link to comment Share on other sites More sharing options...
