W58 set up
Supra374
Hi I’ve just bought a w58 set up but need to know every part I need off the manual car to fit in my auto
W58 box
Shifter
Clutch
Flywheel
Clutch master
Clutch slave
Clutch fluid line
Cross member
Manual tunnel
Manual surround
Anything else please let me know
Do I need a manual prop and ecu
What you will need for the conversion:
Clutch pedal
Clutch fork
Throw out bearing
5 speed manual propshaft (auto is a different length)
Parts that are nice to have but not absolutely necessary:
Brake pedal (can just trim down the auto pedal)
Manual ECU (auto will work fine, but iirc cuts some timing vs the manual ecu)
Bits you'll want to buy new and should not be re-used:
Spigot bearing
Flywheel bolts
I think that's everything.
not really sure, i read somewhere that apparently you have to cut and splice a couple wires if using the auto loom. Correct me if i am wrong but I think the neutral safety switch wire is one of them?
The auto and manual ecu's are a pretty much a plug and play swap with the exception being that the auto loom will require some minor wiring, the starter inhibiter will need to be spliced (just jump these two wires together on the loom), and the wires for the reverse light sensor will need to be wired to the dedicated plug on the gearbox, its very easy and straight forward.
