1996 Supra TT6, 440bhp on stock j-spec, 80,000 miles
Officially the fastest manual car on stock turbos on the forum (See the Drag Racing Hall of Fame :)): http://www.mkivsupra.net/vbb/showthread.php?166336-Supra-Drag-Racing-Times&p=2147216&viewfull=1#post2147216
After 13 years of ownership I feel it’s time for my beloved Supra to move on to a new owner. I cannot justify the insurance any more for the amount of use it gets.
I know that this has been on and off for sale over the past year, but this time it’s for real..!
This is a lovely understated example - you’re not getting a blingy single conversion with loads of gauges all over the place! The car drives beautifully - it’s planted thanks to the suspension rebuild CW did when I first got the car, and now the engine is spot-on thanks to a bottom end rebuild performed by Whifbitz.
Car is located in Swindon, Wiltshire, and inspections are welcome, no test drives without insurance, I’m happy to take you for a drive though.
The headlines are:
1996 Facelift, TT, 6 speed manual, Gunmetal Grey, non-VVTI
Stock twins mapped to 440 bhp by Ryan G at Surrey Rolling Road
Apexi PowerFC
Racelogic TC with Digital Adjuster / Launch Control
AVS Model 5 wheels
Hurst Line Lock Kit
Water Injection
Mint Momo steering wheel with VERY HIGH QUALITY Works Bell quick-release system
Pictures at http://imgur.com/a/YgkvA
Mileage: 80,000 miles
MOT: March 2019
Price - £23,000
Full spec list below.
When I obtained the car from a forum member in 2007 the only modifications were to the body plus a boost controller. All of the other mods were done during my ownership using well known vendors - Chris Wilson, RyanG and Paul Whiffin.
The bad points:
Very few issues considering this a 20 year old car, but there a couple of points to note:
1. The engine warning light blinks on momentarily when you let your foot off the throttle after acceleration. This is really not a big deal, and is caused by the boost sensor reading too low a value on throttle-off. Ryan G explained this to me after our last mapping session and I trust him completely!
The fix would be to fit a 3.0 bar boost sensor (which I will supply with the car) but this would mean another re-map - which I have not done because there would be no benefit until something else changes on the car (FMIC perhaps?).
2. I scratched the bumper getting my bike out of the garage.
3. Passenger side sill has had a scrape/crack and needs to be fixed by a bodyshop, and honestly the rest of the bodykit could do with a touch up at the same time.
4. Incomplete trim in the boot. Stripped this out years ago. Some of the bits I still have, what I have you can have but it might need to be modified to fit around the water injection pump and tank. I have original carpet and didn’t want to cut it.
Full Spec:
Engine:
▪ Stock Internals
▪ Bottom end overhauled by Whifbitz 2000 miles ago
▪ Valve Stem Seals done by Whifbitz 2000 miles ago
Fuel, Tuning & ECU:
▪ Walbro 255 Fuel Pump
▪ APEXi PowerFC ECU with Commander
▪ Mapped by Ryan G (2bar tuning)
▪ Power Enterprise 650cc Injectors
▪ Trac ECU Removed
▪ Racelogic Traction Control w/Digital Adjuster
▪ DM-100 with AFR, EGT and Oil Temp
Turbocharger & Induction:
▪ J-Spec Turbos in True Twin Mode (fully mapped)
▪ Blitz Dual-SBC Spec R Boost Controller
▪ HKS SSQV with Purple Fin Insert
▪ Aquamist Water Injection (50% ethanol)
Exhaust:
▪ Tanabe Touring Medalion
▪ CW 1st de-cat
▪ 2nd de-cat
Drivetrain:
▪ Stock 6 Speed Manual
▪ Limited Slip Diff
▪ RPS Street Max Clutch (good for approx. 600bhp)
Suspension, Wheels, Tires & Brakes:
▪ UK brakes front and rear with CW fast road pads
▪ Brand new front calipers and pads fitted 1000 miles ago
▪ Full suspension rebuild by CW and Geo setup
▪ Yellow Bilsteins and CW springs
▪ AVS Model 5 Rims
▪ Vredestien Sessanta all round. Loads of tread!
▪ Hurst Line Lock Kit
Interior & ICE:
▪ Pioneer Head Unit - Bluetooth and iPod
Exterior:
▪ Top Secret Type 3 Front Bumper
▪ Veilside Skirts
▪ Top Secret Spats
▪ HID Headlights @4300k
Performance:
▪ Best Quarter Mile Time @Pod - 12.1930
▪ Max power - 440 bhp @ flywheel
▪ Max torque - 450 lb/ft @ 4750 rpm
"you’re not getting a blingy single conversion with loads of gauges all over the place!"
Some people like that kind of bling :)
There is a mileage discrepancy with the ad to the online MOT records which have the car at 104k miles. GLWS this time around, can't be an easy call after 13 years together.
