chazuk Posted May 1, 2018 Share Posted May 1, 2018 As the title says got a brand new from Toyota front crossmember/subframe same part for NA and TT it's the black metal section Part number 51201-24031 6 brand new bolts these are £24 from Toyota will include these part number 90119-14038 £300 posted SOLD Link to comment Share on other sites More sharing options...
SupraP-Z Posted May 3, 2018 Share Posted May 3, 2018 Ive been looking for this! Is this usually where the aftermarket intercooler sits on? Link to comment Share on other sites More sharing options...
jim_supra Posted May 3, 2018 Share Posted May 3, 2018 Ive been looking for this! Is this usually where the aftermarket intercooler sits on? No the part above sits further back under the engine. It sounds like you're looking for the radiator support/ front crossmember. (see pic below, one borrowed from a members thread on here) If this is the one you need then it's welded in place, so will need a trip to a body repair shop to have it replaced. Toyota part number is 57104-24021, though people in the past have gotten decent sections cut out of a breaker and welded in. Link to comment Share on other sites More sharing options...
SupraP-Z Posted May 9, 2018 Share Posted May 9, 2018 Ah brilliant, thanks for the detailed response bud - I remember looking at that pic ages ago, unfortunately that is the part i need. Not sure if mine can be straightened out, got a bit excited hoping this would be the perfect fix! Nvm, thanks for that! Good luck on the sale OP Link to comment Share on other sites More sharing options...
Dnk Posted May 9, 2018 Share Posted May 9, 2018 Not big money to buy from Toyota if still available, just over £100 i paid for mine but was a while ago though. Your into a days work to do it properly. its spot welded to the chassis legs. I'd cut out the damaged part if possible then fabricate a piece to go in, very easy to do and saves a chunk of work Link to comment Share on other sites More sharing options...
