R154 conversion help
Supra374
Ok let’s start from the beginning I own a supra na with a auto box and a lsd diff a10b
I’m buying a r154 from a chaser
This is all I have and the car is auto so I need everything
What all do I need to make this conversion happen and is this the right gearbox to get as I’ve been offered a mk3 r154 and a soarer r154 for half the money
What’s the best roof to follow as I’m trying to keep the cost down and don’t know a lot about this.
I know it’s be covered before and there are lots off different things on the net about it but for me it’s finding the balance I need to get everything rather than me trying to piece together something this guy said and something another guy said if you know what I mean
So any help is much appreciated
And if anyone can offer me the parts or send me in the right direction to get them would help
You will need:
Clutch
Clutch pedal
Brake pedal (or cut the auto one down)
Clutch master cylinder
Clutch slave cylinder
Clutch fluid line
Electronic speedo drive
1jz flywheel
Bell housing
Shifter
R154 (extended shifter if mk3)
R154 front half prop
Rear cross member
Custom downpipe support bracket
Gearbox clutch cover plates
Pilot bearing
Shifter
Manual tunnel (or modify the auto one)
Manual ecu (or put up with blinking lights)
Think that's pretty much it
You will need:
Clutch
Clutch pedal
Clutch fluid line
1jz flywheel
Bell housing
Shifter
Rear cross member
Pilot bearing
Shifter
/QUOTE]
hi mate, what do you mean by manual tunnel? thanks
