Samsar Posted April 22, 2018 Share Posted April 22, 2018 Afternoon all, My ‘94 NA auto has been sat in storage since last summer and about a month a go I fired it up but it seemed like the ICV was dirty so took it off and cleaned it up and replaced it. When I started it up this morning it fired up ok but will now only sit at 600rpm straight from start up. I took it out for a run of about 8-10 miles. It seemed to struggle changing gear and when I got back I just turned it off and gave the outside a polish. I thought I’d go for another run with it before I put it away but now it’s chucking out some seriously stinky smoke out of the exhaust. It started off white but has turned black now and really doesn’t want to go at all once it’s in gear. Have I killed it? Quote Link to comment Share on other sites More sharing options...
David P Posted April 22, 2018 Share Posted April 22, 2018 Try treating it to some fresh fuel. Quote Link to comment Share on other sites More sharing options...
Samsar Posted April 22, 2018 Author Share Posted April 22, 2018 Try treating it to some fresh fuel. I put £25 of VPower in it when I ran it about a month ago so surely it wouldn’t of gone off that quickly? Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted April 22, 2018 Share Posted April 22, 2018 I put £25 of VPower in it when I ran it about a month ago so surely it wouldn’t of gone off that quickly? /QUOTE] You sure it wasn’t V-power diesel? Quote Link to comment Share on other sites More sharing options...
David P Posted April 22, 2018 Share Posted April 22, 2018 It won't go off in a month, but it would have in a year. Quote Link to comment Share on other sites More sharing options...
Samsar Posted April 22, 2018 Author Share Posted April 22, 2018 One thing I forgot to add is I’ve noticed water dripping out of the over flow for the expansion tank as well [emoji22] Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 22, 2018 Share Posted April 22, 2018 Normally black smoke is an indication of running rich. Grey/Blue smoke would be an indication of burning oil. Where abouts in Kent are you, maybe I can lend a hand. Quote Link to comment Share on other sites More sharing options...
Samsar Posted April 22, 2018 Author Share Posted April 22, 2018 Cheers mate I’m in Ashford It started off grey smoke but then turned black .. it was the smell that came out of the exhaust. It was rancid Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 22, 2018 Share Posted April 22, 2018 Cheers mate I’m in Ashford It started off grey smoke but then turned black .. it was the smell that came out of the exhaust. It was rancid 濫 /QUOTE] Hmm. Are you still running catalytic converters? Quote Link to comment Share on other sites More sharing options...
Samsar Posted April 22, 2018 Author Share Posted April 22, 2018 Hmm. Are you still running catalytic converters? Yes the cats are in place infact now you mention it that’s the smell .. do you think they’ve could have collapsed inside hence the lack of drive/power(yes I know NA’s lack any power to notice anyway lol) ?? Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted April 22, 2018 Share Posted April 22, 2018 Yes the cats are in place infact now you mention it that’s the smell .. do you think they’ve could have collapsed inside hence the lack of drive/power(yes I know NA’s lack any power to notice anyway lol) ?? /QUOTE] Yeah I would investigate that first. There aren't many other situations where you get a putrid smell, but cats collapsing could do that. Cat collapse could explain your other issues too. If you need a ramp to use to get exhaust off then give me a shout Quote Link to comment Share on other sites More sharing options...
Samsar Posted April 22, 2018 Author Share Posted April 22, 2018 I’ll clamber underneath on a jack and tap with a hammer to see .. you’re an absolute diamond thanks mate [emoji1303] Quote Link to comment Share on other sites More sharing options...
Samsar Posted May 5, 2018 Author Share Posted May 5, 2018 I’ll clamber underneath on a jack and tap with a hammer to see .. you’re an absolute diamond thanks mate [emoji1303] /QUOTE] I’ve not been able to get under till today and the cats do seem to be ok. I cleaned the exhaust out before firing it up and now it’s sooted up pretty quickly getting up to temperature Seriously I’m a complete amateur when it comes to mechanics so please understand if these are dumb ass questions haha Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Samsar Posted July 15, 2018 Author Share Posted July 15, 2018 Update: I finally got to take my car to garage and they done a compression test on the engine and the following was found Cylinder 1 = 100% Cylinder 2 = 60% Cylinder 3= 60% Cylinder 4 =70% Cylinder 5 = 60% Cylinder 6 = Didn’t check gave up [emoji23] They said the piston rings have perished at the bottom due to it not being used enough (20 Miles in 2 years) The options they gave me were Strip the engine and rebuild to stock NA £3500 Strip the engine and prep it ready for a future NA-T £5000 The labour rate was £60 ph and would be 46hrs Looks like it’ll be a garage queen for a few more years [emoji20] Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 15, 2018 Share Posted July 15, 2018 Or buy a replacement engine for £300, couple hundred quid to fit and your on the road again Quote Link to comment Share on other sites More sharing options...
Samsar Posted July 15, 2018 Author Share Posted July 15, 2018 That’s the only option really available. I’m just trying to source one or even go GTE or pre done NA-T Quote Link to comment Share on other sites More sharing options...
