keith 73tt Posted April 20, 2018 Share Posted April 20, 2018 hello folks, just looking for some help identifying a small blue hose coming from the side of the ETCS on my 1997 Jap RZ TT . the hose is clipped to the side of the throttle cable and is pretty much following it into a hole in the back of the drivers side wing ( near the bulkhead ) it is leaking air and i can see that it has totally perished and snapped off from whereever it terminates !. for info the blue hose comes out of the ETCS into a small white connector of some sort then continues as a small black hose down into the wing. it was the hissing o the air that alerted me to the problem - i could actually hear it coming from the drivers footwell to begin with. any and all help much appreciated ! Quote Link to comment Share on other sites More sharing options...
David P Posted April 20, 2018 Share Posted April 20, 2018 http://www.mkivsupra.net/vbb/content.php?51-Repair-Manuals Quote Link to comment Share on other sites More sharing options...
fastcar Posted April 20, 2018 Share Posted April 20, 2018 It’s normally for a boost gauge or a boost controller. It’s taken from the plenum as pressure reference Quote Link to comment Share on other sites More sharing options...
Burna Posted April 20, 2018 Share Posted April 20, 2018 I like to call it 'Harry', Harry hose Quote Link to comment Share on other sites More sharing options...
keith 73tt Posted April 20, 2018 Author Share Posted April 20, 2018 I C wut u did der Burna...:clap: Quote Link to comment Share on other sites More sharing options...
keith 73tt Posted April 20, 2018 Author Share Posted April 20, 2018 It’s normally for a boost gauge or a boost controller. It’s taken from the plenum as pressure reference Thanks Pal.. next question will be how to get at the f*&kin thing Quote Link to comment Share on other sites More sharing options...
keith 73tt Posted April 20, 2018 Author Share Posted April 20, 2018 http://www.mkivsupra.net/vbb/content.php?51-Repair-Manuals Thanks for the reply David ...but I just got hit with this little message .... keith 73tt, you do not have permission to access this page. This could be due to one of several reasons: Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or a members only section? Please see here for details of what sections are only available to club members. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 20, 2018 Share Posted April 20, 2018 Thanks for the reply David ...but I just got hit with this little message .... keith 73tt, you do not have permission to access this page. This could be due to one of several reasons: Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or a members only section? Please see here for details of what sections are only available to club members. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. I guess you've not paid to be a full member yet hence the restrictions Quote Link to comment Share on other sites More sharing options...
keith 73tt Posted April 20, 2018 Author Share Posted April 20, 2018 It’s normally for a boost gauge or a boost controller. It’s taken from the plenum as pressure reference there was an aftermarket Apexi boost guage in the car when I bought it mate. There seems to be a constant supply of air coming from the hose as soon as i start the motor... i presume it needs to go back to the same spot it was plumbed into ? looks like a pig to get at it though...front wing off after taking off he veilside side-skirt ( skirts are getting old and fragile ) . would I be right in saying the car should run fine...but just that the guage would not be functioning.. thanks again. Quote Link to comment Share on other sites More sharing options...
MRX Posted April 20, 2018 Share Posted April 20, 2018 Can probably be removed then if you no longer have the Boost guage? Quote Link to comment Share on other sites More sharing options...
keith 73tt Posted April 20, 2018 Author Share Posted April 20, 2018 Can probably be removed then if you no longer have the Boost guage? boost guage is still in the car mate... Quote Link to comment Share on other sites More sharing options...
MRX Posted April 20, 2018 Share Posted April 20, 2018 there was an aftermarket Apexi boost guage in the car when I bought it mate. Ahh OK i presumed you had it removed as you said there was an Apexi. Does the guage you have now still work then with this hose leaking air? Quote Link to comment Share on other sites More sharing options...
keith 73tt Posted April 21, 2018 Author Share Posted April 21, 2018 Ahh OK i presumed you had it removed as you said there was an Apexi. Does the guage you have now still work then with this hose leaking air? just checked and the answer is no ! further to that i found the broken end of the perished hose just above the accelerator pedal, so i will just run in some new hose. thanks for all the replies chaps ! Quote Link to comment Share on other sites More sharing options...
