JayJay1374 Posted April 19, 2018 Share Posted April 19, 2018 Hi guys, looking for some advice. What are the symptoms of dual mass flywheel failures? I’ve got an annoying knock on the car, when normal driving and letting off the throttle there might be a slight clunk/knock/rattle occasionally and again after repressing the throttle, I’ve done a bit of research and it does fall towards DMF problems. I fitted a second hand unit 4 years ago when building my engine, I checked and it was within factory tolerance when fitted. It was fine when first fitted, but say the last 2 years I’ve started to notice it. Before I take the gearbox out to check has anyone got any other suggestions? Car is a V160 TT Cheers JJ Link to comment Share on other sites More sharing options...
Scooter Posted April 19, 2018 Share Posted April 19, 2018 If it's happening with no clutch inputs from you ie just throttle on/off then I think it points to something else in the drive train? Maybe the prop rubber couplings or engine/gearbox mounts etc might be worth checking? Link to comment Share on other sites More sharing options...
JayJay1374 Posted April 19, 2018 Author Share Posted April 19, 2018 I’ll have to have a drive of it and double check whether or not it’s happening with clutch input Link to comment Share on other sites More sharing options...
Scooter Posted April 19, 2018 Share Posted April 19, 2018 Actually to be fair (it's been a while since I had a manual) I think at low speeds it can clunk and it be the dmf, if you are at normal road going speeds I'd suspect the dmf less and less. I remember rolling and with no throttle, quickly lifting/dumping the clutch and getting a repeatable clank on engagement which I think is definitely a sign of it being the dmf being worn. Link to comment Share on other sites More sharing options...
JayJay1374 Posted April 19, 2018 Author Share Posted April 19, 2018 I’m pretty sure the clunk is at low speeds, to be honest your describtion of rolling and lifting the clutch might be along the same lines, I’ll get it out this weekend and have a go Link to comment Share on other sites More sharing options...
squiffy Posted April 19, 2018 Share Posted April 19, 2018 I have the clonk when going on and off throttle without using the clutch. Changed to a solid flywheel, changed the gearbox mount, changed all the diff mounts, checked the prop doughnut and hanger bearing.....still does it. It also makes a small knock as I shift from neutral into first before I pull away Link to comment Share on other sites More sharing options...
Swampy442 Posted April 19, 2018 Share Posted April 19, 2018 Ive only ever had it on a diesel, and it was a constant chattering at idle, but drove spot one in any other respect Link to comment Share on other sites More sharing options...
JayJay1374 Posted April 21, 2018 Author Share Posted April 21, 2018 After abit of investigation I’ve adjusted the clutch bite, as I suspected it might be dragging. Anyway the car feels a lot better to drive, but I still have a light thud when when cruising in 5th/6th. As before when coming back onto the throttle after coasting in gear. Any suggestions? Link to comment Share on other sites More sharing options...
Tyson Posted April 22, 2018 Share Posted April 22, 2018 (edited) I think a good indicator of a failing dmf is the death rattle at low speeds. Does yours rattle a bit when pulling off ? Try doing WOT on full boost in 5th and 6th and see if you get a spike in revs similar to when your clutch is slipping this will also indicate a dmf on its way out. Edited April 22, 2018 by Tyson (see edit history) Link to comment Share on other sites More sharing options...
