SupraP-Z Posted April 17, 2018 Share Posted April 17, 2018 Where my intercooler piping goes down from the Y-branch manifold (Im NA-T) and through the hole made just behind the headlight...over bumps the pipework grazes against the cut hole in the metal, making a creaking type sound. What can i use to cushion the hole so that the pipework is protected as well as no noise made? Quote Link to comment Share on other sites More sharing options...
jim_supra Posted April 17, 2018 Share Posted April 17, 2018 I'd either stick a strip of foam on the pipe where it rubs, or use some rubber tube, split length-ways ( so can make a C shape) and place that round the edge of the opening. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 17, 2018 Share Posted April 17, 2018 As above, or get some 3mm silicone hose, slice it down it's length, and feed it around the edge of the hole Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted May 3, 2018 Author Share Posted May 3, 2018 Cheers guys, any way of sticking it down so it doesnt move around? Silicone? Quote Link to comment Share on other sites More sharing options...
jim_supra Posted May 3, 2018 Share Posted May 3, 2018 (edited) Shouldn't need to stick it down, the intercooler pipe sitting on it should keep it in place. I'd also slit the hose along it's inner edge - the hose will naturally want to coil itself up - slit along the inside of this coil. Then when you place it round the hole in the inner wing it will push itself against the edges of said hole (as it tries to coil back up) and keep itself in place. hope my explanation is OK!! Edited May 3, 2018 by jim_supra (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted May 9, 2018 Author Share Posted May 9, 2018 Cheers, will give this a go and see how it fares! Quote Link to comment Share on other sites More sharing options...
