Use Lq9/ls2 or VAG Coils with Aem v1?
Silece2k6
Why are you changing the stock coils?
Is it because the AEM v1 converts from direct fire to wasted spark, the old fix for this was a HKS ignition amp, I ran that setup on stock turbos and then again on a single up to 1.8bar using the stock coils.
I have a Hks dli installed. The Problem is missfire above 1.5bar in higher gears 3-6. We tried new coils (oem denso and the red ones) with new plugs bkr8eix (gap 0.5) and bcp7r. All missfired. We tried coils and plugs from a 1xxx hp Supra running 2.2bar without any diffrence.
Coilplug connectors are new ones. May I have to check the wirings from igniter to coils?
Gesendet von iPhone mit Tapatalk
