D1andonlyantman Posted April 14, 2018 Share Posted April 14, 2018 Hi all. Just been poking around as you do with a relatively new car, and have found it's got a Toms ecu. Is that anything of interest or is it pretty standard stuff? Thanks Quote Link to comment Share on other sites More sharing options...
D1andonlyantman Posted April 15, 2018 Author Share Posted April 15, 2018 I'll post what ive found out, so this isn't a dead thread.... Apparently the Tom's has a more aggressive fuel map, timing map, higher fuel cut, and no speed limiter. I'm not sure how exactly, but someone said it's good for 550bhp, but seeing as it's still not mapable which I guess means you can't change turbo and injectors etc, I don't see how. Doesn't sound like a bad thing to have though Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 15, 2018 Share Posted April 15, 2018 They are the same as the blitz and mines ECUs. Typically, they are all mapped for bpu, with a daughter board soldered into a stock ECU. They generally are set up for: Fuel maps for boost to 1.2bar More aggressive timing Raised rev limit Speed limit removed Decat and exhaust Quote Link to comment Share on other sites More sharing options...
D1andonlyantman Posted April 15, 2018 Author Share Posted April 15, 2018 Ah ok cool. Mine is still stock other than intake, but it'll be BPU soon enough. Sounds like a nice surprise then Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 15, 2018 Share Posted April 15, 2018 TOMS ones are one of the better ECU's. As you said generic tweaks, timing, fuelling, boost cut and speed cut removal. BPU will make better use of it Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 16, 2018 Share Posted April 16, 2018 Ah ok cool. Mine is still stock other than intake, but it'll be BPU soon enough. Sounds like a nice surprise then Yep, a nice thing to have, to get the most out of bpu upgrades Quote Link to comment Share on other sites More sharing options...
