Dave Posted April 13, 2018 Share Posted April 13, 2018 can anyone reccomend a good sealer for the underside going to do it my self so spray can or paint on would be best . Link to comment Share on other sites More sharing options...
peter richards Posted April 13, 2018 Share Posted April 13, 2018 you got access to a lift mate I did a bit on mine over the last few months but tough on the floor Link to comment Share on other sites More sharing options...
Dave Posted April 13, 2018 Author Share Posted April 13, 2018 you got access to a lift mate I did a bit on mine over the last few months but tough on the floor cant guarantee i can use the lift ,just lucky that day .done most of the floor with brush on [MESSY] want to do the rear section Link to comment Share on other sites More sharing options...
MattL2708 Posted April 13, 2018 Share Posted April 13, 2018 On my mini I used gravitex stone chip, brilliant stuff Link to comment Share on other sites More sharing options...
Scooter Posted April 13, 2018 Share Posted April 13, 2018 Loads of products recommended here, the dinitrol stuff I think is good. http://www.mkivsupra.net/vbb/showthread.php?344513-Under-body-cleaning&highlight=cleaning Link to comment Share on other sites More sharing options...
Marty Posted April 13, 2018 Share Posted April 13, 2018 Por-15 Link to comment Share on other sites More sharing options...
Style Posted April 13, 2018 Share Posted April 13, 2018 Dintrol then U-Pol Raptor Link to comment Share on other sites More sharing options...
Sheefa Posted April 13, 2018 Share Posted April 13, 2018 Dintrol then U-Pol Raptor Agreed. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 13, 2018 Share Posted April 13, 2018 Equally important is a good cavity waxing job. Stop it rusting where you can’t see it! Link to comment Share on other sites More sharing options...
jackso11 Posted April 14, 2018 Share Posted April 14, 2018 Raptor is what we always recommend. If I ever buy a brand new never driven car that would be the first thing I do to it. Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 14, 2018 Share Posted April 14, 2018 Best treatment, don't drive it in the wet Link to comment Share on other sites More sharing options...
jackso11 Posted April 14, 2018 Share Posted April 14, 2018 Best treatment, don't drive it in the wet Link to comment Share on other sites More sharing options...
Dave Posted April 14, 2018 Author Share Posted April 14, 2018 Thanks will look for raptor Link to comment Share on other sites More sharing options...
Ian Ian Posted April 15, 2018 Share Posted April 15, 2018 Look at Frost.co.uk they sell good quality stuff Cheers -Ian- Link to comment Share on other sites More sharing options...
Axl Posted April 15, 2018 Share Posted April 15, 2018 Strip back k-rust where any surface rot is Wax oil in the cavity’s And then gravi-tex Link to comment Share on other sites More sharing options...
Dave Posted April 15, 2018 Author Share Posted April 15, 2018 Look at Frost.co.uk they sell good quality stuff Cheers -Ian- Will do thanks Link to comment Share on other sites More sharing options...
rider Posted April 16, 2018 Share Posted April 16, 2018 You can use my indoor 2 post full rise lift if that'd help. Actually, it really would help in this kind of task. To do the job properly you'd need a few days spare and to park yourself up overnight in a local hostelry or rent a cheap Enterprise car to get yourself home each evening. You'll need lots of sandpaper, sanding discs, wire brushes (all sizes). I use Aquasteel rust converter, dinitrol 3125, Zinc primer and then just over paint with POR or standard acrylic. With a smooth paint you'll be able to see quicker when rust returns that if you apply a thick coating. You'd need to decide how far you want to take it, which bits you want to work around and which you'd take off for better access. Side pods, hockey stocks, road wheels and heat shields are probably a minimum to remove but then you need to think tank guard and the ultimate would be sub frame off but then you are into a bit of a project that could run for weeks rather than days. Link to comment Share on other sites More sharing options...
Burna Posted April 16, 2018 Share Posted April 16, 2018 Here's what was used on mine: http://www.mkivsupra.net/vbb/showthread.php?343109-Burna-s-UK-Spec-Restoration&highlight=burna+restoration Link to comment Share on other sites More sharing options...
