Uk spec vs k sports
Adam2jzzz
Have a read of this, the comparison was done a while ago - http://www.mkivsupra.net/vbb/showthread.php?225007-Big-Brake-Kits-Real-Numbers
More info here - http://www.mkivsupra.net/vbb/showthread.php?249089-Supra-Brake-setups
CW’s view below.
What are you using the car for? Short of out and out track day usage the stock UK brakes are more than adequatem given good pads and good condition calipers. Braided hoses make a noticeable difference in pedal firmness. Race fluid makes absolutely no difference to stopping distances, but will not boil until later, but is unlikely to be worthwhile for road usage. It absorbs water quickly, and if not changed regularly can cause corrosion issues and soon degrades to worse than "normal" fluid. Even Jap spec brakes can be made to survive hard track usage, albeit with exotic pads and fluid, and high attrition.
Edited by Frank Bullitt (see edit history)
