dfrancis85 Posted April 2, 2018 Share Posted April 2, 2018 HKS Twin plate clutch, not 100% sure on model as came with my car. (Perhaps someone on here knows?) Was working before I pulled the engine/box from my car. It's and ideal upgrade for anyone going single. Obviusly comes with clutch bolts and sold state flywheel (HKS) Looking for £425 delivered anywhere in the UK. Advertised elsewhwre. Link to comment Share on other sites More sharing options...
curious Posted April 2, 2018 Share Posted April 2, 2018 Pm sent. Thanks Link to comment Share on other sites More sharing options...
James Posted April 3, 2018 Share Posted April 3, 2018 Could be the HKS GD. I used to have one of those. If it is, they often require a different carrier hub to OEM and the bearing/washer setup needs to be modified accordingly to get it to sit right. I'll check in the garage and see how it looks compared to my old one (I can't recall off the top of my head). Link to comment Share on other sites More sharing options...
Tabz Posted April 3, 2018 Share Posted April 3, 2018 Interested. Are you able to measure plates and does it come with the fully push to pull bearing kit set up? Link to comment Share on other sites More sharing options...
dfrancis85 Posted April 7, 2018 Author Share Posted April 7, 2018 Interested. Are you able to measure plates and does it come with the fully push to pull bearing kit set up?Hi, Sorry for delay took ages to find my mircometer! The plates have 4.4/5mm edge to edge. From what I've read they came with 4.6mm new so should have some miles left on her. This was bolted to a 2JZ GE NA with a V160 (the previous owner planned to do NA-T but it never happened) so has had a relatively easy life. It comes with everything to make it work with a v160 / 161 as it it's was pulled from my running car. Link to comment Share on other sites More sharing options...
Tabz Posted April 7, 2018 Share Posted April 7, 2018 Check pm Link to comment Share on other sites More sharing options...
dfrancis85 Posted April 13, 2018 Author Share Posted April 13, 2018 Bump Link to comment Share on other sites More sharing options...
dfrancis85 Posted April 15, 2018 Author Share Posted April 15, 2018 Sold pending payment Link to comment Share on other sites More sharing options...
dfrancis85 Posted April 26, 2018 Author Share Posted April 26, 2018 Sold Link to comment Share on other sites More sharing options...
