UK spec ... Under Bonnet fabric Heat-Shield
ARPUS
I'm looking for a new fabric under bonnet heat-shield, for my UK spec Supra.
Would a new Jspec version fit, after I cut out the bonnet scoop area?
If so, I would consider that too.
Most used fabric heat-shields would be in fairly poor condition, as they would be over 20years old.
Thanks, Steve
I’ve been looking for the same. You can’t get a new UK one but you can get a non hood scoop shield and just cut the hole out - it is even marked on it. I’ve just ordered one - around £150. Part number - 5334114110
Pm sent. I use megazip.net who are excellent. With this item would be worth going to local Toyota Dealer as I have been told is available and in stock from Japan. Due to size of item, delivery costs are substantial but Toyota would just charge cost of part (I assume).
No worries, can send some pics of the new part when it arrives if that helps but it seems to be the same part minus the hole for the bonnet scoop.
Where did you order from mate? Mr T?
Megazip.net
It is probably available from Toyota but I was lazy. Should be cheaper from them as delivery cost from
Japan is expensive but I know they have it.
Thought I would give a quick update as the Bonnet Heat Shield arrived today. When placed next to the old one, it feels lovely. Also got some new clips and, after cutting the hole for the bonnet scoop, a doddle to fit. Really pleased with it.
[img]https://i.imgur.com/R4dbiyy.jpg[/img]
[img]https://i.imgur.com/fjwIj1D.jpg[/img]
[img]https://i.imgur.com/DQABlDE.jpg[/img]
[img]https://i.imgur.com/U0UEKkV.jpg[/img]
[img]https://i.imgur.com/8KBRVvN.jpg[/img]
