crazy engine 1.5jz forged goodness
jonny mac
** I will add the template shortly, can't copy paste just now.
this is purely testing the water, I am looking to move house and solicitor fees after selling etc are insane, looking to get some money back towards them so me and the wife can downsize our house
the engine is a 1.5jz engine, 2jz block 1jz gte head, front sump
it is insane, nothing sounds like it, the car has the most incredible note and just has to be heard in person to appreciate
so the head:
1jz gte soarer head FULLY BUILT
brett sims motorsport full port job inc chamber balancing, opened up as much as it can go (£1500)
bc 264 camshafts and adjustable gears, valve bucket shims setup correctly by bret sims (£1000)
bc titanium retainers and valve springs (conceptua £300 ish)
Toyota engine gasket set inc new valve stem seals and every head seal replaced (£300)
image102 by Jonny McIntosh, on Flickr
image101 by Jonny McIntosh, on Flickr
image94 by Jonny McIntosh, on Flickr
the block:
2jz ge from mkiv supra, machined out for gte oil squirters and turbo oil feeds (£300 in machine work for oil passageways to open up)
DY engine services block (around £3500)
wossner forged pistons
zrp rods
new bearings and arp bolts
crank balanced
86.5mm oversized to allow perfect seal on rings with new engine
block hot tanked and acid bathed
decked surface, correctly machined
- - - Updated - - -
image106 by Jonny McIntosh, on Flickr
image107 by Jonny McIntosh, on Flickr
image110 by Jonny McIntosh, on Flickr
new oil pump Toyota, ported out inside too
image111 by Jonny McIntosh, on Flickr
image109 by Jonny McIntosh, on Flickr
- - - Updated - - -
image108 by Jonny McIntosh, on Flickr
new Toyota oem water pump, custom pipework to make the 1.5 head setup fit
image100 by Jonny McIntosh, on Flickr
welded cam gear, new Toyota oem timing belt, tensioner, pulley set
image99 by Jonny McIntosh, on Flickr
brand new water neck with an6 feed added
image92 by Jonny McIntosh, on Flickr
new oil squirters
image91 by Jonny McIntosh, on Flickr
new gaskets, coolant/cam/crank sensors etc
image90 by Jonny McIntosh, on Flickr
Toyota parts
image89 by Jonny McIntosh, on Flickr
gasket set
image88 by Jonny McIntosh, on Flickr
image86 by Jonny McIntosh, on Flickr
brand new crank pulley
image87 by Jonny McIntosh, on Flickr
arp head studs used
image93 by Jonny McIntosh, on Flickr
image114 by Jonny McIntosh, on Flickr
- - - Updated - - -
image117 by Jonny McIntosh, on Flickr
image121 by Jonny McIntosh, on Flickr
image122 by Jonny McIntosh, on Flickr
image148 by Jonny McIntosh, on Flickr
image158 by Jonny McIntosh, on Flickr
so where I'm standing right now is I have more than 10 grand sunk into an engine in a car that is currently not moving and won't be going anywhere anytime soon due to insurance costs etc etc as moving house is my priority for this year for my family
the engine was ran in on a dyno with correct oil changes using run in oil, then changed over to the oil in above photograph and changed again
it's currently done around 800 miles in total I'd say, since mapping has been finished I've done one drift day in the car on wastegate pressure at 1 bar, it made minimium 400 and something bhp on wastegate pressure
at 1.6 bar of boost it's over 600 and something we reckon, couldn't tell due to wheel spinning and was going to go back to dyno with big 305 tyres on but never got a chance last year before insurance expired
I'm just trying to get the feelers out there, I don't actually want to sell this as i've built my dream car/combo but if it basically means I can nail my solicitor fees then i'll be happy and can always do this in the future especially with my experience now
it's a basically brand new engine, every sensor and every gasket/component was brand new
the price for the tall block inc intake manifold and 90mm throttle body will be £7500 o.n.o
tall block being, sump, block, head and intake manifold only.
I know I'm going to get an absolute kicking from the forum for asking that price but I am unfortunately in a position where I have to sell....so meh take from that what you will.
I will do a full list when I get a chance including things like £150 powdercoated rocker covers etc etc,
consider the amount of money spent on this and the Toyota invoices....
happy for compression tests and stuff to be done, it has never overheated etc during my time and on the track day I went to without a thermostat it got nowhere dangerous
it won't include the turbo setup/injectors/ecu as they are staying for the next jz i'll throw back in there in a year or so.
this will fit in a mkiv nicely with some mods and could easily take on a big turbo for those 1000hp supra builds haha
  • 2 weeks later...
