Boost keep increasing on its own
stwinn
I have a '96 TT JDM.
The boost increases by itsel when I drive the car hard. It keeps increasing untill the fuel cut kicks in. I use a Blitz boost controller and it is set to 11 pounds. However the boost keeps climing higher when I run the car hard. I have disconnected the boost controller and left the car stock but the problem still happens.
Does anybody have any idea why the boost pressure would go up by itself?
Thanks for your help in advance.
Sorry about that, I'm new to this.
Here is a little background:
My name is Todd, I live in the Cayman Islands.
I have a 96 Supra TT that I brought in from Japan (used).
It seems to be stock except for the triple plate clutch.
It had a boost controller in it, but part of it got stolen in shipping.
I have put in: Blitz SBC boost controller, Blitz intercoller and a downpipe (no cats).
These are the only modifications I have made.
Thanks again,
Todd
You did read the rule about new members having to offer existing members free holidays didnt you :p
If youve got no cats then that is why you are overboosting , the controller can only increase boost not reduce it , you may need to fit a restrictor in the exhaust or put the front cat back on , but if its not going over 1.2 bar i wouldnt worry .
John:flame Dev
BTW the free holidays members with post counts over 2000, unless you live in the UK.
Does sound like classic boost creep, if you only have a single pipe replacing both cats you will need a restrictor, if you have one repalcement pipe for each cat try sticking the smaller cat back in and see if that cures it. You will need a FCD chip to raise the fuel cut limit as well.
With a car like Supra you need a mech that really know the car.
I was really worried last Saturday that I blew my turbo as I had this horrible whininhg noise on acceleration.
I took the car over to Toyota for a check.
They had it on the ramp for 20 minutes with two engineers checking things over. They could not establish the fault.
I posted one question on this forum, about 10 minutes later I had a reply. About 15 minutes later I found a small vaccum pipe on the EGR sensor cracked.
Replaced that with the new one.
The car is running sweet!! It feels like someone had just given me a new trubo or lots of ££££.
Stick with the guys on here. You will always get a lot of help.
Cuba
A boost contoller can only raise boost, not actually control it. If your system has the potential to go over the boost controller limit then it will, unless you restrict your exhaust system to give a maximum boost level below the max level on your controller.
IMHO you dont need a bost controller on a J spec with no cats and stock turbos.:flame Dev
hi and welcome, there is a lot of helpful people on here.good place to be for info.when i got my supra i did not know of this board. could have done with the info.
the search is a good thing but its always nice to get feedback.
also i have j spec with no cats and exhaust. dont have a boost controller too.always could not see point getting a boost controller if its hitting up to 1.4bar. its a bit on high side. they say 1.2 is a safe limit.
if you get stuck i am sure someone will help.sometimes gets boring to some people when the same questions keep popping up.
Originally posted by stwinn
Why won't the boost controller stop the boost when it reaches my max setting (18 psi)?
I think the waste gates on the stock j-spec turbos are too small to flow enough exhaust gas past the turbine to stop the turbos spinning up when the rest of the exhaust system is de-restricted (no cats or restrictor ring), that's why the boost controller can't do anything about the boost creep.
The common solution here seems to be fitting a restrictor ring in the exhaust system to stop the boost spiking. This allows the Wastegate to regain control of the situation. The other not so common solution is to port the wastegate. I'm guessing a turbo swap to UK tubbys would also solve the problem but these may need other supporting changes.
^^ Think I've put the above in order of expense.
